samsung LE46A558P3F weird image quality and vertical lines.
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    hi, i have this tv that show exactly same problem as this one on that video:
    https://www.youtube.com/watch?v=MW3x6eGT_Yo
    and also menu popup start to flicker, plus one side get almost all white.
    and like this dude problem too like tv get white on some corner and so on.
    https://www.badcaps.net/forum/showthread.php?t=41381
    board is the usual and well popular: BN41-00974B
    is that problem as-15f related , or are the ribbon cable that connect t-con to tv?
    on that youtube video, someone talk about y axis driver problem... , but as i have no experience with tv, dunno what to do except change as15f
    Re: samsung LE46A558P3F weird image quality and vertical lines.
    The problem shown is for a plasma display, so it would be rare for your LCD to show these symptoms, are you sure?
    Or is it more like THIS:
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      tnx for reply. yes difect is a bit different. today for example screen become almost all white. i changed now as15f with a new one and problem remain for the first 5-6 second when start tv. after that time tv works very fine
      must be some capacitors related ?
        Sounds like a panel tab bond failure, non repairable and will only get worse... very common on Samsung sets unfortunately.
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          looking better, tv seems to start just fine and after 10 seconds , color and quality get worse.
          ill make a video later with an hdmi source.
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            here is the video, hope that it's not the lcd but some electronic fail.
            http://youtu.be/WBOCGxYpLjg
              Video is marked private for me.
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                try now... all should be ok.
                  Unfortunately looks like a defective LCD panel to me...
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    up the lcd, there is a screw, if i touch it i make lcd turn brighter or sometimes that problem get less worst.
                    edit: i did soem other test. that crew is just the bright control so nor problem with that. but i tried disconnect 1 by one t-con cable to lcd and still the same, then on the t-con if i put a finger on one chip thermal pad, i can hear a heavy noise that ir produce. so can it be a bad t-con or that king of problem just lies to a bad lcd panel ?
                    dunno if i got some problem with batteries, but when tv goes almost all white, it become also unresponsive to remote control pushing.
                    can i try this to check better?
                    https://www.youtube.com/watch?v=GcBwTums_mI
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      update: today ive disassembled lcd and even if i touch lcd ribbon cable, nothing happen, so as tom66 said i suppose it's lcd 100% as also t-con make some noise and if i disconnect ribbon from t-con to lcd that noise disappear
                      im going to sell all parts for spare.
                      is t-con ok or it can get damage too because dunno if selling it is ok or not..
                      • Falki
                        Colorful LCD Vertical Lines on Samsung ue55es8090
                        by Falki
                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                        A similar issue has been posted as well but also with no actual response ...
                        Today, 04:19 AM
                      • Stanley1843
                        by Stanley1843
                        06-29-2024, 11:54 AM
                      • x_orange90_x
                        Samsung UN46C8000XFXZA vertical bars/horizontal lines
                        by x_orange90_x
                        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                        09-04-2023, 12:09 PM
                      • polaro
                        Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                        by polaro
                        Greetings,
                        I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                        08-27-2022, 08:46 AM
                        09-07-2024, 05:50 AM
