LG 50PQ10 Probable PS issue.
  • Gary_B
    • Oct 2014
    • 14
    I have a LG 50PQ10 and it just stopped working.
    The symptoms are a little different from what I have read online though.
    The failure was sudden. We came home and there were NO lights, blue or red and it just acts like its not plugged in. The cord is fine and so is the power outlet.
    In a sudden and complete failure like this could it just be a fuse?
    Gary
    Re: LG 50PQ10 Probable PS issue.
    It's possible, but more likely to be a little more complex.
    Do you have access to a digital multimeter? Any prior testing experience around electronics?
    • Gary_B
      • Oct 2014
      • 14
      Hello Tom, Thank you for the quick reply.
      Yes, I have considerable experience in electronics but none in modern TV's I have a DMM and good soldering tools and skills.
      Let me tell you exactly what happened.
      My wife accidentally switched off two power bars, the internet box was plugged into one and the TV was plugged into the other. I only realized there was a problem because I couldn't get online. We turned on the power bars but the TV didn't and wouldn't turn on. I tested the power cord and it was OK, I made sure it was connected firmly and tried turning the power on and off many times.
      Then I posted on this forum.
      The next day we plugged it back in and it has worked perfectly since! It even got an unintentional torture test that night. There was a pretty big wind storm and the power went off and back on again faster than I could get up and switch off the plasma. Then over the next 20 minutes it happened FOUR more times! (I should have switched it off) It has worked flawlessly since.
      I suspect it simply needed a power drain after the accidental cut off of power when the power bar was switched off caused perhaps by noisy operation of the switch. But if that is the case shouldn't the FIVE storm outages have caused the same issue?
      Still kinda worried that it will give out but I know I can replace the caps and that power regulator and fuse if I have to. So nice that the information is so easily available for this power supply.
      So for now I guess it's "thanks but all is well" unless there is something you think I should check or do?
      Gary B in BC with LG :-)
        There is no reason a sudden power on/off should cause issues. I have done it many times with a lot of TVs with no long term harm. They are built for such fault conditions. However it could be an indication of a developing intermittent fault. Run the set for some time, but if it does occur again, it will not have been anything relating to your failure to unplug the set.
        • Gary_B
          • Oct 2014
          • 14
          So far so good! Thanks!
          • dcapper
            • Dec 2013
            • 496
            I have the same model that acted up the same way. It's probably the Ysus. I checked mine. The fuse is blown and there is 7 transistors showing shorts. Chances are it's just one or two of them. I will pull them and test tonight to let you know what I find.
            • Gary_B
              • Oct 2014
              • 14
              Well this time I am sure I really have a problem. I am also quite sure it is unrelated to the previous non issue. I will post a new thread with various voltages, pictures and such once I pull the back off and have a look but I thought I'd just post a quick description of the unusual symptoms in the hope that somebody will know what's happening from their own experience.
              We only use our 50" LG 50PQ10 for watching computer files through HDMI.
              I was asleep on the couch and woke to find the TV apparently timed out and off as you would expect after a file finishes playing and you don't shut anything off. The red light was lit and there was no sound. (normal).
              I walked up and used the main power button to shut it of then turn it back on again. The light went from red to blue to red to blue VERY quickly (may be normal it always does this now and it's so brief that I am not sure that it didn't always do this) then flashed blue one time then came on steady blue. (once again I am not sure if this is what I always see on power up or not so this may be normal). After the usual delay it clicked normally but there is no picture and it made a sound that starts out high pitched for about one second then drops an octave or two and continues like that forever.
              The TV reacts normally to the remote and as I said the light seems normal (I think). It does not turn off or flash any other light patterns. It does the same things exactly no matter if it has been unplugged or if I turn it on and off with the remote or with the power switch. When I play a file from the computer the sound seems normal except for the buzzing.
              The sound does not seem to be coming from the speaker, when behind the set it seems to come from the right top corner. The back is still on so it is hard to be 100% sure, it may be coming from top center.
              I am involved in a big project for the next 5 days and will not be able to remove the back and check any voltages or anything until Wednesday July 8th. at the earliest.
              I just hoping somebody will recognize "LG plasma, normal lights and remote function. Normal click but no picture does have sound with buzzing from upper right" and can tell me what happened.
              I will still want to verify with checks but I am hoping for a running start.....
              Thanks all, this is a great forum, far better than most and I am into homebuilt airplanes. Those guys are INTO helping!
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • shahnld
                Lenovo legion 5 pro startup issue
                by shahnld
                Good day Experts
                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                08-24-2025, 12:31 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
