Bizarre behaviour Hisense - 42 inch LCD
  • Grogamanda
    • Oct 2014
    • 3
    Hi all....
    This may seem odd but the other day, my daughters TV stopped working and began emitting a high pitched whine...and nothing else.
    So, I thought, lets open her up and see what we can see.....Took the back off...checked the Caps etc. nothing. Plugged it in - worked perfectly!
    reinstalled the backpanel, reinstalled wall bracket, checked it again before I put it on the wall....All good!
    Put it on the wall, High pitched whine and nothing else.
    Took it off the wall, plugged it in again in my work room - Worked perfectly.
    Took it back into daughters room - plugged it in before hanging it - worked perfectly....
    Hung it on the wall.....High pitched whine....Bizzare...I think it might be a dry solder joint thats getting stressed when I hang it....
    Any thoughts at all??
    Cheers in advance...
    Richard
  • tw2005
    • Oct 2011
    • 6458
    Re: Bizarre behaviour Hisense - 42 inch LCD
    Originally posted by Grogamanda
    Hi all....
    Richard
    could very well be or something may be pinching. I have read a similar story, no idea when , brand or model so have no idea what key word to do a search.
    Is it possible to leave the back off, then mount and hang and see what flexes?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Mounting screws too long, touching and shorting something....?
      TELEFIX
      • tw2005
        • Oct 2011
        • 6458
        Good point!
        • Grogamanda
          • Oct 2014
          • 3
          WOW - Fast responses!
          Unfortunately, that was the first thing I checked....The upper ones have
          10 mm clearance and the bottom ones are actually in the backpanel....and contained....so not touching...
          The thing is, it works with the bolts in when its on the floor lol.
          Cheers
          Richard
          • Agent24
            I see dead caps
            • Oct 2007
            • 4978
            • New Zealand
            If it works when lying down, perhaps it's a bad solder joint somewhere and when mounted vertically the weight of the component causes it to disconnect.. Check the power supply for bad solder joints.
            -David VanHorn
            • Shinju
              • Mar 2014
              • 1239
              Sounds like a wire being pinched some place, I had a Sammy 5084 that would work perfect on a stand, put it on the wall mount and it wouldn't turn on all all.
              Come to find out there was a wire being pinched between the back shell and the bottom of the panel itself. It came from the factory like this.
              Take the back off and start hunting!
              Also I repaired a 2013 JVC LED that had the same issue, from the factory there was a wire harness being smashed by the back shell on the wall mount bolt frame.
              • Coolgoodman
                Faulty Hisense 85Q6NAU TV
                by Coolgoodman
                85” Hisense TV
                Greetings,
                Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                Dear TV technicians of forum, I hope this message finds you well.
                I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                07-24-2025, 03:02 AM
              • ShahZaib Ghumman
                Can I Swap Screens Between Two Hisense 75” QLED TVs?
                by ShahZaib Ghumman
                Hey folks,
                I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                03-25-2025, 10:59 PM
              • nono34
                Hisense stuck in Colors cycle like test pattern.
                by nono34
                I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                10-24-2024, 04:31 PM
              • Federause
                HP 250 G7 - Battery Issue (Lid behaviour)
                by Federause
                I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
                It has a particular behaviour that I've never seen:
                With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
                09-08-2024, 03:34 AM
              • dabushar
                Hisense A6100 Files Request
                by dabushar
                Hi guys, I want to try revive a motherboard for a hisense 55 that only lights up the motherboard. does any one have the emmc files ? any help is appreciated. i have seen the emmc pinout on kenotrontv https://kenotrontv.ru/files/file/746...ag78207918roh/
                08-18-2025, 03:57 PM
