Panasonic LED TV Dead after EMMC dump
This topic has been answered.
  • BigPete
    • Jul 2012
    • 80
    • New Zealand
    I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
    The dump was successful and the program finished without errors.
    I used a XGecu T48 to do the dump.
    I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
    One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
    I also shorted out the crystal of the adjoining ECU together and at one point to ground as I was having issues get it to start and this was also mentioned in the online manual.
    I used an ISP programmer for the dump.
    My goal is to try and resurrect a similar board with a bad EMMC chip. I have the new 4GB EMMC chip and have uploaded the dump to it with a BGA programmer. I'll send it to an electrics shop to solder it on for me.
    Fingers crossed it works, but I can't even get the original board going now which is annoying.
    Can someone shed some light on possible things I could've done wrong or should check please?
    The TV I'm repairing is a 85X940Z. The EMMC was bad and confirmed with a bad dump. The dump completed, but the verification failed.
    The donor board is from a 65X900A. I plugged it in and the TV fired right up. So I know it used to go.
    Thanks.
  • Answer selected by BigPete at 03-20-2026, 07:11 PM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8882
    Well… I did a similar thing before. Dumping an eMMC on board through ISP (flying wires) to an RT809H. While the dump was good, the Android TV box didn’t boot anymore. Found out that each data line has a resistor and for some reason one of them had changed value.
    Other than that check that the crystal works. No life there, the main chip is going to do sweet diddly squat. A faulty BGA solder joint also will have the same behaviour. Needless to say you better get that Oscilloscope out and start checking things out.
    if you want to read about it find my thread about a DreamLink T1. It has some useful info in there.
    Doing eMMC repairs isn‘t easy and sometimes something effs off faster than you can say “bag”!
    • Diah
      • Feb 2013
      • 6763
      try discharge the MB / eMMC completely, to let it back to first sector.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8882
        • BigPete
          • Jul 2012
          • 80
          • New Zealand
          Thanks for that CapLeaker, that info lead me to what the problem actually was.
          The 56 ohm resistor on the CMD Line unalived itself and became open somehow.
          I feel a bit stupid to how simple the solution actually was. I even had a spare board that I could've compared it to originally, but didn't even think to check values of resistors around the EMMC chip.
          I swapped over the resistor from the old board to the new one and it booted straight up.
          Thanks again for the lead.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8882
            Good that you found the problem. These little resistors are a pain in the rear and can cause big trouble.
            Glad the info got you on the right track.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4889
              • Italy - Milan
              those resistors are low value and so very atomic size matherial inside, them fries instantly, i got mad on the first attempts on inline wire progromming, so maybe the only one method is removing the emmc, it's also been a while that my suspect of reason why emmc fails is indeed the leaky solder balls, so think about learning some bga rework skills..
              • BigPete
                • Jul 2012
                • 80
                • New Zealand
                I haven't yet stepped into the area of BGA rework. I don't often need to do it so at the moment would rather pay someone to do it for me.
                I'm going to try a crowd locally, but don't mind paying someone else to do it if it stacks up financially.
                I really enjoy learning new things and the whole ISP programming thing has been a nice learning curve, though it can be frustrating as well, but that's all part of it I guess.
                I often buy used boards from broken TVs instead of doing a BGA rework when I can.
                I've also got an LG 84UB980T that needs the ECU reballed, that I'll get someone else to do.
                Ultimately I'd find a mate who would do it for free in exchange for other services, as bad as that sounds.
                It's really disappointing how poorly some BGA chips are setup. Panasonic seem to have one of the better setups with LG the worst.
                Overall it's disappointing how poorly some of the BGA implementations are and how easy it is to rectify, but overall it's shit as most people just bin electronics that can be repaired.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4889
                  • Italy - Milan
                  I thought to avoid touching the resisters , to scratch the track that belongs to it and solder the wire there..
                  when people will be warned enough to do what i say and repeat with bga chips when new, they will never needs bga rework and also emmc sw reprogram... and set ups will be no longer trash binned..
                  • lotas
                    • Jan 2016
                    • 5398
                    • Russia
                    eMMC suffers from wear and tear, not from BGA soldering.
                    https://www.kingston.com/blog/embedd...emmc-lifecycle
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4889
                      • Italy - Milan
                      I don't want to discuss again the same things, my opinion is the one i have enunciated, until a demonstration of the contrary, when i will have time and luck to.get deeper into emmc technology especially the interface i shall be more sure..
                      • BigPete
                        • Jul 2012
                        • 80
                        • New Zealand
                        That's exactly what I believe is wrong with many electronics using EMMC, they get to end of life, many far too early.
                        I'm not as skilled or knowledgeable as many people here, but I've witnessed many TVs failing due to aged EMMC chips with TVs not booting or having a boot loop.
                        If this particular TV wasn't an 85" that I picked up for a 5er, I wouldn't of wasted my time.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4889
                          • Italy - Milan
                          The end of the discussion is: desolder a known bad emmc, put it in a programmer with cleaned pads, restore it to factory defaults, with cleared data/ empty BBT / cleared registers if any, if it is possible, then write new data and verify the behaviour through the long time, stop.
                          • lotas
                            • Jan 2016
                            • 5398
                            • Russia
                            If the eMMC is obviously faulty, you won't be able to do anything with a programmer (the eMMC won't even be detected by the programmer). The eMMC has an internal controller with its own firmware that monitors the health of the NAND memory. When its health (resources) are depleted, the controller blocks access to the NAND, and you won't be able to do anything, including erase or write any dumps to the eMMC. For example (this is the same thing), take a non-functional HDD or SSD that isn't detected by the system or the BIOS. Try formatting it, installing an OS on it, or on a half-dead HDD or SSD. See how the PC will work afterward.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4889
                              • Italy - Milan
                              Years ago i've heard in a pro only technical forum that emmc could be managed somehow like BBT table erase and so on, depends maybe on the programmer, for the SSD discourse i have personally restored two SSD SATA with special software tools by replacing for example the internal microcontroller firmware.. etc etc.. , plus, emmc usually do not fail competely in a tv set, the set is able to load something before to abort, this means also a programmer can detect it..
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8882
                                That depends on which resistors we are talking about. The Data Line resistors no.
                                • testo420
                                  Samsung Odyssey G9 C49G95TSSR FA01 - image lost, backlight stayed on, now completely dead - dump request
                                  by testo420
                                  I'm working on a first-generation Samsung Odyssey G9 C49G95TSSR, board revision FA01, with mainboard BN41-02787A / BN94-16145A and a Novatek SE19HM01-NT scaler.
                                  The failure happened as follows:
                                  On the first power-up, the monitor displayed a normal image for approximately 5 seconds and showed an "HDMI connected" message. The image then completely dropped out, leaving only the backlight on, similar to a classic failed thermistor / T-CON thermal shutdown symptom.
                                  I disconnected the main AC power and plugged it back in to reboot...
                                  09-22-2026, 09:11 AM
                                • cccamgeek
                                  Need firmware dump for Samsung 320MX-3 / LH32BPLBC - Board L-HA32MWWAF-1006.0 - W25Q32 dead
                                  by cccamgeek
                                  Hello all,I need help to find a working SPI dump for this Samsung LFD monitor.Model: Samsung LH32BPLBC / 320MX-3 / HB32PS
                                  Board marking: L-HA32MWWAF-1006.0 (66B3)
                                  BN label: SK10BN9404049QD2U4BBE0003 - 14.11.2011
                                  Main chip: STDP scaler
                                  SPI Flash: W25Q32 / MX25L3206E (8-pin, bottom right of board) - DEAD, cannot read IDSymptom: All power rails OK (3.3V, 1.8V, 1.2V), no standby LED, no boot. SPI flash is dead (programmer reports fail ID).I have TL866 universal programmer and new W25Q32 to program.Does anyone have a verified dump (W25Q32 + 24C512 if possible) for this board?Thank...
                                  11-06-2026, 02:14 PM
                                • Zasche
                                  Need W25Q80DV (1 MB) SPI dump – ASUS ROG Strix G17 G713PI, 6050A3468901-MB-A01 (USB4 dead after erase)
                                  by Zasche
                                  Title: Need dump of small W25Q80DV (1 MB) SPI chip – ASUS ROG Strix G17 G713PI / 6050A3468901-MB-A01 (USB4 dead after accidental erase)
                                  ASUS ROG Strix G17 G713PI (board 6050A3468901-MB-A01, same board as G713PV).
                                  What happened: a BIOS update from USB stick got interrupted. I recovered it by replacing the main BIOS chip (Winbond W25R256JW, 32 MB, 1.8 V) with a freshly programmed one. The BIOS now works and Linux (CachyOS) boots again.
                                  The problem: before I found the real BIOS chip, I accidentally erased the second, small SPI chip without...
                                  11-07-2026, 06:45 AM
                                • Andreas_de
                                  Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                  by Andreas_de
                                  Hello!
                                  i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                  Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                  Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                  04-12-2025, 10:38 AM
                                • g1150
                                  Panasonic TV TX-50DXW784, Mainboard TNPH1147, Processor dead
                                  by g1150
                                  I have a Panasonic TV with a main board TNPH1147.
                                  The Problem is:
                                  - not turn on
                                  - no LED indication
                                  - Mains power consumption 5Watt = STandby current
                                  - all voltages 5V, 3.3V 1.2V, 1V are OK
                                  - crystal pins voltage = 0.7V, Scope didnt show any oscillation. (24MHZ)
                                  The main Processor is completely dead.
                                  The MediaTek MT5810PEHJ is a quad-core Smart TV system-on-chip (SoC) featuring a combination of ARM Cortex-A17
                                  and Cortex-A7 cores running at 1000 MHz.
                                  Has anybody ever had such...
                                  09-05-2026, 09:44 AM
