I am trying to repair a 50 inch Hisense RG50 model TV that has solid red light when connected to power point and no change when attempting to power on the TV from hardware button.
Backlight does not come on and no image on LCD screen when checking with a flashlight.
This RG50 tv has next boards in it:
- PSU board number: RSAG7.820.8364.
Found no close schematoic for it. After cleaning the annoying Conformal Coating from the ICs I found it uses IDP2303 for PFC and the 3 voltages 12V, 16V and some 40V used for backlight (40V supposed to be 60V).
Also uses IW7027 QFP IC (manufactured by Dialog) located on the little green PCB module for LED strips drivining.
RSAG7.820.8349 has a part of schematic that uses IDP2303 IC but outputs 200V for backlight instead of 60V.
This PSU drives 16 strips of LEDs.
- Main board number: RSAG7.820.8269
I have tested the 16 LED strips with an Aliexpress backlight LED tester (29mA contant current)- all 16 strips have 44V in direct conduction (I see them lighting up) and 9V when tested in reverse.
I found the mainboard outputs 3.3V to the STB pin of the PSU but zero volts to PSU BSW pin that is supposed to turn on the backlight LEDs.
I used a jig made of 2xAAA batteries to test if PFC works and when applying 3.3v on PSU STB pin I see the voltage going from 320V to 380V on the caps. Also 9V standby voltage goes to 12V and the other voltage goes from 12V in standby to 18V.
With PSU disconencted frrom mainboard -> I aplied 3.3v on both STB and BSW pins but backlight voltage does not go over 40V - also I cannot see any LED strip lighting up.
My understanding is that with 3.3v on both STB and BSW pins the backlight LED strips were supposed to light up. Unless it needs some continus 3.3v voltage or 3.3v TTL pwm signal applied on PSU PWM pin too to turn on the backlight?
PSU does not seem to work as it should.
I confirmed that the voltage regulator LM117 3.3v on the LED drive QFP IC boatrd works ok and outputs the 3.3v.
Trying to find if the problem is in mainboard or in the PSU. Mainboard CPU feels slightly warm after power applied to mainboard for 5 min or more.
I uploaded some PSU pics
