LG 60px950-UA no remote reception after main board replaced
  • Truncatedhose
    • Oct 2014
    • 343
    This TV originally had the common symptom of shutdown after brief flash of raster and I replaced the main board EBR71767001 (subbed to a EBT61259501) which repaired the problem, but now I have NO REMOTE RECEPTION.
    I could not find any loose plugs or cables and everything seems fine.
    I thought it might need a firmware update, but I cannot select that option in the TV menu without a remote control.
    I have tested the IR board and found that I can see AC voltage on one of the pins of the IR receiver rising whenever a remote is discharged into the IR receiver, so it seems that the problem is not there.
    Can anyone help me to see if my main board is defective or where the problem may be?
    Thanks!
  • Truncatedhose
    • Oct 2014
    • 343
    Re: LG 60px950-UA no remote reception after main board replaced
    Is it okay to bump this thread up to the top?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      I would guess it needs a different remote.
      A working TV? How boring!
      • Truncatedhose
        • Oct 2014
        • 343
        Well, tried three different verified remotes...so...I would surmise that's NOT the issue.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Is it exactly the same mainboard....?
          If not, you could try one of those 'universal' remotes and try some different codes to see if that helps out....
          TELEFIX
          • Truncatedhose
            • Oct 2014
            • 343
            It is from one of my LG distributors and is a sub, but looks visually identical. They say it is the correct sub part for the original part number. I am having them do some research to confirm that it is a correct sub.
            I guess it's possible that a different IR frequency might work than the LG one that it's supposed to work on, but I don't know. I will wait and see what the research returns and report back.
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • Asraf Atb
              by Asraf Atb
              01-27-2025, 05:02 PM
            • yoyokafka
              M60-C3 Replaced PSU & Main Board: Still No Good
              by yoyokafka
              My tv only goes to the splash/logo screen then turns off and repeats this on its own every couple minutes. I replaced the main board and got the same thing. So I replaced the power board and still got the same thing.
              Could it be the T-Con? The logo screen indicates it's processing the image and outputting to the screen and triggering the LEDs just fine. But could there be something with the communication between the T-Con & the main board that prevents the main board from continuing it's bootup into it's operating system?
              Someone please help me figure out what...
              09-23-2020, 06:52 PM
            • cmlewis89
              LG 47LB5DF blown power supply board
              by cmlewis89
              Hi folks,
              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
              09-03-2024, 07:50 PM
