sony kdl-46xbr6 slow refresh
    Re: sony kdl-46xbr6 slow refresh
    This device is fairly simple. You can check if it is in regulation by probing the FB1/FB2 pins (6&11) - these should measure almost exactly 0.8V each.
    • freakaftr8
      • Oct 2012
      • 3743
      Agree. I'm almost certain it's the switching controller ic. Just for good measure I ordered replacements.
      • freakaftr8
        • Oct 2012
        • 3743
        Crap. The one somewhat working tcon crapped out. Blank screen. Was getting ready to test voltages. All fuses still good
        • freakaftr8
          • Oct 2012
          • 3743
          Got the tcon back working. It managed to blow a link resistor between pin 2 and 3 off the IC. This makes be back up my assumption that the IC is bad. Your thoughts? Altgough pun 1 and 2 are fet output pins and the link blew between the IC pin 1 and 2. Hmmm see pic
          http://i845.photobucket.com/albums/a...psd5wl5rea.png
          • freakaftr8
            • Oct 2012
            • 3743
            Btw. The tcon also took out the fuse on the mainboard. Replaced fuse and that resistor on the tcon and its back working. And I'm getting .8vdc in pin 6 and 11 of the bad board. So it at not be the IC after all
              Try measuring pins 7 and 11 too.
              • freakaftr8
                • Oct 2012
                • 3743
                well I went ahead and replace that IC No change. so its gotta be something else but I'm not sure what could cause this off and except for incorrect voltages going to the IC possibly?
                  Are the FETs it drives OK?
                  Output caps OK, not shorted?
                  Check volts across output capacitor on both.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    The fets are the 8 pin regulators located to the right of the IC correct? Pin 2 and 3 go into pin 4 of the fets as a gate driver. The fets as far as I can tell with a diode meter test ok. This doesn't necessarily mean they are good though? Usually I'm looking for a bridged connection.
                    All capacitors on the board appear to be ok.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      It appears the circuit in question drives the 1.0v to the DDR2 ram. The output of the fets goes one to a microprocessor on the other side.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Well got the new regulators in today. No change. So it's not the regulators or the driver ic or any shorted components in the area. I'm stumped. Could it be what they are driving? The bottom voltages and controllers in question go to the ddr2 ram on the tcon and also go to the processor with sony etched on it.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          okay update I started probing around the board it sounded is shorted MLCC capacitor off the PLL 1.0 volt rail which is the rail that was in question. Replaced shorted capacitor still have same slow motion picture. What is the PLL 1.0 volt it looks like its controlling the main video processor which is the chip labeled Sony Cxd9935gb.
                          I would like to note that this circuit out of all four voltages on the board is the only circuit that has a very low ohms reading across all the capacitors. Roughly 43 Ohms. even on the board that produces a good picture but only last for a few minutes until it goes to vertical stripes has 43 Ohms across. does seem a little odd but I can't find any shorted capacitors on either the working or the non-working board. Even when I had the voltage regulators removed from the board I still got 43 Ohms across the pins
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Ok should have looked into this closer. essentially there's four voltage outputs. it appears that the first voltage output is 3.3 volt. Second voltage output is 1.9 volts. Third output voltage is 1.8 volts and the last output voltage is 1.0 Volt. this is on v good bored that works for a little bit. On the bed bored both of these middle voltages are 1.8 volt. My question is why would they have two independent rails running the same voltage? Unless something's wrong
                              PLL 1V is for the CPU, it's the PhaseLockLoop power supply.
                              The rails might be independent because of noise concerns - or if they power up separately or in sequence.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                I'm giving up on these t-con boards it just blew a main board fuse on mainboard. In my opinion not worth the hassle anymore as I believe it is a processor issue no. And in that case BGA no thank you. on the other hand on the other t-con board is the AS15 chip supposed to get super hot within seconds
                                • bluetinc
                                  • Sep 2013
                                  Hey, I figured I'd chime in here as I'm chasing the same problem with the original failure showing as the TV shutting down after a few hours with a 14 Flash pattern, finally not displaying anything with F603 blown.
                                  So far, like you guys, I've tracked this to the 1.0V Core power for the Sony Cayenni-T. I've taken the power switcher out of the circuit and powered the 1.0V externally and everything looks perfect. That isolates this into the switching supply. I'll keep you guys updated.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    did you have the usual slow image problem after replacing f603? 2 tcons I have presented this after replacing the fuse.
                                    The other has perfect image for 5 mins then fades out.
                                    Can you elaborate on what switcher you removed and where you injected the 1.0 volt.to and where did you get the voltage from? Think we may be on to something. I've already replaced the 4 diodes and the fuse and the two 9853a ics and the rss040p03 and the rss040n03 power ics to no avail. So that almost sums up the switching circuits.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      AS15s have always had a high failure rate, could be a problem there. I don't know if they usually get real hot like that. I've only ever seen the bleached out, and negative picture with them though. Other than that, maybe a processor issue. Could explain why they're rare and expensive.
                                      ------------signature starts here------------
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        This particular board does not use an AS15.
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          Oh, I misread your earlier comment about the AS15.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
