Samsung PN51E550D1F
  • Treydogg77
    Treydogg77
    • Mar 2013
    • 99
    • US
    Samsung PN51E550D1F
    I've got a Samsung PN51E550D1F with some vertical noise/lines. Would what cause this? Logic Board, Main Board, or the dreaded panel?
    Thanks for any help or advice!
    Trey W
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung PN51E550D1F
    Is this with every source? ( Cable/Blu ray etc ).
    I would open the back of the tv and reseat the cables going to the screen , or did you already try this?
      Bad plasma panel. Seems to be a problem with these models unfortunately. Why does Samsung have so many panel issues? (LCD or plasma!)
      • Treydogg77
        Treydogg77
        • Mar 2013
        • 99
        • US
        I haven't tried any other inputs, because the lines appear immediately when the tv is powered on. I will try cleaning and reseating the cables. I did tear it down and check the tabs "applied pressure" where the lines are appearing, that didn't change anything. I am afraid that Tom may be right again tho! How can Samsung keep producing panels that only last 12-14months, and not have a class action law suit?
        I will post my results on cleaning the ribbion cables and reseating them.
        Thanks again for the replies and advice!
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-07-2024, 05:50 AM
