Panasonic th-42phd6 dead but has green led
+ More Options
Posts
  • freakaftr8
    • Oct 2012
    • 3743
    so I'm repairing this TV for a friend. TV powers up with green light and immediately you hear a high pitch whine from the power supply board then a second later click the TV shuts down but the green LED stays lit. Fans shut down with the click and I'm getting high voltage to the SC and SS boards. I've tried disconnecting each board and I still get the high pitch whine and the green light stays lit but everything powers down. Having my assumptions that the power supply board is indeed faulty but not too sure yet I've tried disconnecting buffer boards and that didn't help. I checked for shorted MOSFETs and I can't find any. What's odd is that on the SS board the red LED attempts to light up but not on the SC. Any ideas?
    Re: Panasonic th-42phd6 dead but has green led
    Do you have Vsus, Vda and 15V?
    On SC board, is -Vad and Vscn present?
    • freakaftr8
      • Oct 2012
      • 3743
      Hi Tom. That's what I'm curious about. Most Panasonic plasmas that I work on have clear labels on the boards for test points this one doesn't have any I don't know where all the voltages derived from the power supply is no label on the screen depicting I can't find a service manual.
      VSUS voltage is fine that comes up and then powers down immediately
      • freakaftr8
        • Oct 2012
        • 3743
        for the moment that I can get it to power up it appears that I have all voltages. Vda reads 35v. VSUS 173v. 15v comes up but won't stay on long enough to to read properly. On sc vscan and vad present. Vscan does not have enough time to come up I can only read about 14 volts vad -60v.
        • freakaftr8
          • Oct 2012
          • 3743
          I guess I should say that originally I said a high pitch whine from the power supply it's not really a whine it almost sounds like a beep from a digital watch. and it's either coming from one is large filter caps or a transformer
          • freakaftr8
            • Oct 2012
            • 3743
            Power supply model tnpa2889 and the sounds coming from the hot side.its hard to isolate
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              I've had several chirping power supplies ( not panasonics though) that had shorted output diodes. I would say it is in the secondary or possibly heavy load from another board otherwise it would blow the fuse.
              Liberating magic smoke one part at a time
              • freakaftr8
                • Oct 2012
                • 3743
                True. But thus a dead beep like sound for only a split second then all voltages shutdown after the relay clicks out. I've attempted to isolate sc board but the way panasonic are wired it's impossible to isolate SS board.
                  FWIW, I've had some whining power supplies where the whine is normal. Including an older Panasonic (PV500, similar generation to PHD6.)
                  • Caleb
                    Smokin IC's
                    • Feb 2013
                    • 645
                    Have you resistance tested the secondaries?
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      yes I have resistance tested the secondaries already. this is not like the other chrips are flubs I have heard on power supplies relating to loose coils or chokes this is definitely a sound of a that short of some type but oddly I can't seem to find any shorted components on the power supply board thus far
                      • Caleb
                        Smokin IC's
                        • Feb 2013
                        • 645
                        Only way I can think of to isolate is by pulling individual outputs out of the connector until you find the overloaded one, that is assuming that its not on the power supply. Could be that the short is beyond a relay in which case you would have to current test each voltage source. Maybe Tom has a cheat sheet showing how to fire the power supply without any boards connected?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          hopefully because I have tested both sustain boards and are goodI've also checked almost every diode resistor in my set transistor on the power supply and all tests within spec but I'm getting this odd sound out of the hot side of the power supply near where the mains connect and the power supply only spins up for a split second then clicks with a shutdown but the green light is still on. I've never seen a Panasonic Plasma shutdown without an error code.
                          also in my experience if there's a dead short on the hot side of the power supply it would blow something up in the TV wouldn't work at all because that side of the power supply is always on. This sound may be coming from a transformer that's rather small but it's really hard to tell by ear.
                          btw power supply model is tnpa2889.
                          • tw2005
                            • Oct 2011
                            • 6458
                            It's a pretty old model so would not expect the same level of onboard monitoring. i know i briefly touched a 2005 panny and it had a main board issue and shutdown, no error blinks on that one either. Just sat there with a non responsive red LED , how rude.
                            I have a huge 4 part PPT presentation for the 2006 PD60 maybe there's something that can be used for fault finding? Not sure if I can upload would take a long time
                            • tw2005
                              • Oct 2011
                              • 6458
                              42PX25 has same PSU
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Nice thanks a million! Going to look into these schematics.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Well all voltages appear to be there. The 7 v standby is low at 5v. The 5v is spot on but 12 and 15 appear to be low. But hard to tell at split second intervals. I might be looking for a capacitor issue possibly. Have to r an esr over them. None appear shorted although.
                                  • nobbnobb1
                                    Panasonic TC-P50U50 Powers Off - 8 blinks
                                    by nobbnobb1
                                    I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                    2x DG302 (Q16051)
                                    2x RF2001 (D16041)
                                    2x 5.6 ohm SMD resistor
                                    1x BD8694 IC
                                    I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                    03-21-2023, 08:33 PM
                                  • jimjoe123
                                    LCD TV Green/Pink screen problem
                                    by jimjoe123
                                    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                    Then each time...
                                    02-23-2020, 01:29 AM
                                  • JSBJSB
                                    Panasonic OLED TX-65GZ950E no image
                                    by JSBJSB
                                    so I have this problem with this OLED that had a LED blinking issue at first.
                                    It was blinking twice so it means according to similar service manuals (I cannot find the proper one) EVDD 24V SOS, Panel or TCON Fault.
                                    Also, the connector from PSU to TCON which supplies 24V was burned (changed it) and saw threads about this topic but didn't relate completely to mine.
                                    First thing was to tape the signal ERRORDETECTION so it would try to initialize. And it didn't so I unplugged the panel from TCON.
                                    Then it started up and went to green light...
                                    05-14-2025, 02:39 PM
                                    HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                    This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                    09-12-2024, 02:00 PM
                                  • badcappo
                                    Dead Panasonic Viera TX-P65STW50 Plasma TV
                                    by badcappo
                                    Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                    Diode type G972s6 - D101 with a short
                                    Mosfet 06N90E - Q301 shorted
                                    Fuse T5AH 250V - F103 blown
                                    Diode D301 shorted
                                    Relay DG1U-17VDC II - RL001 blown
                                    I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                    11-24-2024, 11:27 AM
