Samsung QN75Q90TAF (Q90T) with single vertical line and horizontal lines bottom of screen
  • Chris24
    • Feb 2014
    • 57
    Have a Samsung Q90T that has a single thin vertical line on left side. (See pictures)
    When I apply light pressure at the bottom of screen along line, more vertical lines appear then disappear.
    Also along the bottom of screen is about an inch of horizontal lines.
    Before I tear it apart, and start inspecting driver boards, tab bonds and the Tcon, first wanted to see what the community thinks. Is it a shorted led and thus a bad panel anyways?
    The picture is amazing otherwise.
    Click image for larger version  Name:	IMG_6181.jpg Views:	0 Size:	3.42 MB ID:	3821375 Click image for larger version  Name:	IMG_6180.jpg Views:	0 Size:	6.26 MB ID:	3821377 Click image for larger version  Name:	IMG_6177.jpg Views:	0 Size:	2.64 MB ID:	3821378 Click image for larger version  Name:	IMG_6182.jpg Views:	0 Size:	3.52 MB ID:	3821374
  • Chris24
    • Feb 2014
    • 57
    Would a single black line be a bad pixel or potentially something else?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4687
      • Italy - Milan
      Them are not bad pixels, do not ask me how to fix this issue..
      • Chris24
        • Feb 2014
        • 57
        Thanks. If you don’t think it’s a bad LED I’ll put effort into other potential issues as I research, thx
        • EazyBone
          • Jun 2023
          • 1419
          • United states
          • Anything I can do with my hands
          Line up and down bad cof connection?
          Lines across, bad panel?
          I wouldn't waste my time unless for fun. I have seen some videos try and undo a cof tab and solder it back on and it did actually work. Don't think I would be able to accomplish that but Ive considered trying.
          Interested if you do manage to accomplish something
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4687
            • Italy - Milan
            Detachement of tab pins is only a myth, but the problem is still in the tab, or call it fpc.. i cannot say more ..
            • Chris24
              • Feb 2014
              • 57
              Thanks gents, super helpful. I was going down a rabbit hole on cof and will keep going.
              The picture on this tv is great, tempting to leave it, but just as tempting to get it right. Thx
              • jmartins
                LG 55UC970V-ZA: vertical bands/lines appear after ~2 seconds, then clear, repeating
                by jmartins
                I have an LG 55UC970V-ZA (around 10 years old). The picture is normal right after power-on, but after ~2 seconds vertical bands/lines appear across the screen. Then it clears again, and the issue repeats in a cycle (roughly every 2 seconds).
                Symptom (repeatable):
                - After power-on, the picture is normal for about ~2 seconds.
                - Then vertical bands/lines appear across much of the screen.
                - It happens on everything, including the LG boot logo and the TV’s own menus/OSD, built-in apps, and all HDMI inputs.
                - Power-cycling (unplugged...
                01-10-2026, 07:58 PM
              • Stanley1843
                Screen Display Vertical Multicolor Lines
                by Stanley1843
                Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                06-29-2024, 11:54 AM
              • Smallen
                Can anyone tell if this is a fake TV screen overlay (e.g YouTube) to make it look damaged?
                by Smallen
                I hired an apartment which I did not stay in as it was not as described (not enough beds), they refused to refund, even though I had to pay for another accommodation. After I left bad reviews, the owner got hostile and is refusing to refund me and is also keeping my deposit of £250 as he said we broke the TV (we didn't) he sent this photo as proof. I checked with Gemini Pro 3 and it thinks it's fake (a screen overlay), I'm trying to get a human viewpoint as do not fully trust AI, but I did not break anything so I'm being scammed. Can. Anyone help or confirm if below is accurate? Thanks
                1. The
                01-26-2026, 11:02 PM
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
              • sputnikoff
                samsung un58tu7050 single vertical line.
                by sputnikoff
                Had a friend drop this tv off and initial issue was no power.I could see faint glow when powered up .Lamps all fired up fine.I removed flat lvds cable and reseated it,then tv screen came on.After i reassembled it now has single line pretty well dead center of screen.Is there ongoing display issues anyone is aware of.Any input welcome.
                02-25-2023, 09:42 AM
