Replace an LG 49UH850V cracked diffuser
This topic has been answered.
  • sdancer75
    • Jan 2017
    • 24
    • Greece
    This specific model, LG 49UH850V, is 3D. The problem here is that the diffuser has been cracked at the bottom, where the LED strip is installed, due to the heat from the LEDs. This is a common problem for many LGs and Samsung TVs.
    The questions here are
    1) Can I replace the diffuser from a non-3D LG TV with the same size (exact fit)?
    2) If I replace the diffuser with the original part, do I have to replace the LED strips also? They work as expected, but some technicians recommend replacing them together.
    Regards,
  • Answer selected by sdancer75 at 02-09-2026, 12:47 AM.
    EazyBone
    • Jun 2023
    • 1440
    • United states
    • Anything I can do with my hands
    Yea as davi says and I thought I implied as well, it's for the light. It will work most likely. I've found some of them have different thicknesses, but they have still always worked even with the difference.
    The sheet or sheets that are on top of the diffuser should be saved for the same TV, don't transfer a different tvs sheets to the 3d tv though.
    • EazyBone
      • Jun 2023
      • 1440
      • United states
      I replace diffusers from different tvs all the time. They work fine. They have to be edgelit diffusers as the other ones which have full array won't work.
      I would replace the LEDs also .. they are generally like 20$ on eBay or cheaper if you do AliExpress.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4889
        • Italy - Milan
        3D or not 3D doesn't apply, the leds normally do not heat too much, the fact that them has done means them are not perfect or the power board has a problem, my brother's Samsung developed trough last years some halos on the bottom, then one day leds failed, maybe two, this means the test of few seconds is not enough to say leds are ok, furthernore leds testers do not apply much current..
        long story short: replace leds.
        • sdancer75
          • Jan 2017
          • 24
          • Greece
          Yes,maybe the LEDs need to be replaced but the 3D reference here applies to the diffuser and not for the LEDs. So the question was if a 3d TV uses a diffuser with a special design, specifically for TVs that are able to view 3D pictures.
          • sdancer75
            • Jan 2017
            • 24
            • Greece
            Yes edgelit diffuser I meant from the begging, I didn't clarify this sorry. So, as your are saying that 3d is not important in this case, diffuser has the same design as non-3d TVs.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4889
              • Italy - Milan
              but i arleady answered this, 3D or non 3D doesn't matter, the diffuser is only to diffuse the light!
              • EazyBone
                • Jun 2023
                • 1440
                • United states
                • sdancer75
                  • Jan 2017
                  • 24
                  • Greece
                  Thanks to both of you :-)
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4889
                    • Italy - Milan
                    The topmost sheet, the thin one, is the back polarizer, doesn't matter about 3D or non 3D..
                    • sdancer75
                      • Jan 2017
                      • 24
                      • Greece
                      excellent !
                      • sdancer75
                        • Jan 2017
                        • 24
                        • Greece
                        After a long time, I found the opportunity to replace the diffuser and the LEDs (the latter preventively, but both are compatible as I couldn't find original LG ones). The 3D and everything else work normally, but truth be told, I wasn't very satisfied with the brightness. From the middle and up, the white color looks like light gray and not real white. What could be causing this?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4889
                          • Italy - Milan
                          i don't know which one of the two not original parts defects, my opinion is more the diffuser sheets, maybe are designed for direct led or for both borders light source, otherwise the leds has no enough power to deliver light to all the panel, impossibile to say
                          • sdancer75
                            • Jan 2017
                            • 24
                            • Greece
                            Thanks, Davi.p
                            There are two problems here....
                            1) The white brightness (photo 1) using https://www.youtube.com/watch?v=QggJzZdIYPI&t=466s. The degradation you see here occurred on my phone, so you can ignore that, but as you can clearly see, the top part is grayed out. No clear white.
                            Can you clarify if the diffuser was installed correctly? The glossy surface was positioned to face the panel, and the textured surface to face the back, and it sits above the LED strips.
                            2) Sometimes the TV crashes (photo 2) with a whistling sound and immediately shuts down. After that, it works again. I suspect a short circuit, so the power supply protection is activated by default. Note that the reflector white sheet behind the diffuser was ripped off a little bit at its base (leds side), and I glued it with aluminum tape from the back side.
                            Does this create static electricity, or something that creates the short circuit? Or maybe the T-Con cables are misaligned a little bit? This happened 3 times in a period of 3 working days.
                            It seems that I have to open it again. Any recommendations?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4889
                              • Italy - Milan
                              1) the sequence is right but there is always a middle sheet, plus there are usually some plastic transparent spacers between the back and the sheets.
                              2) unfortunately it is something about the processor soldering, needs reballing, my bet, it's the same reason why led failed, oxydation
                              for the aluminum tape it does not affect electrically but visually i think yes, better was the glue like vynil glue
                                Back Again?
                                • 32841
                                Or it's run many hours at max brightness
                                Rtings found that most edge LED TVs have short lifespans at maximum brightness
                                My advice is run 75% brightness or lower if the TV is running for long periods of time. Since human eye's response to light is logarithmic, 75% brightness setting uses about 50% of the current, and power dissipation is around 40% compared to full brightness.
                                For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
                                Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
