dp42740 sanyo green light on/off power fail mode
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: dp42740 sanyo green light on/off power fail mode
    took me a minute but the only components it shows inline are R1682, L1673 and L1674. If you have 15v at p24 test point one of those has to be open or you would have voltage to your diode 1671. R1682 and R1683 look like they form a voltage divider, R1682 is specified at 0 ohms, the manual doesn't give a value for R1683 you might have to get out your magnifying glass and see if you can read the numbers.
    Liberating magic smoke one part at a time
    • lively
      • Sep 2012
      • 44
      lol man this is weird , r1682 good has 15.6 vdc , L1673 good has 15.6vdc , L1674 good has 15.6 vdc , ( all of course go low once audio is not picked up .. and both diodes did cero out to O ohms and both are 0 ohm diodes ... SMH !!!! i will refuse to let this set take me out !!! and the p24 test point has 15.6vdc as well
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        At the beginning you stated the audio power was the only one giving error, where did you measure the error if not at D1671?
        • lively
          • Sep 2012
          • 44
          at the beginning i was testing off the test point on top side of board at 13v audio power , but i just checked at D1671 and it has 4.678vdc- 5.100vdc when i switch leads when i applied power ..
          • Agent24
            I see dead caps
            • Oct 2007
            • 5096
            • New Zealand
            #45
            Which exact service manual are you looking at? I looked on Tom's site and there are 20 files which come up for "dp42740"
            -David VanHorn
            • lively
              • Sep 2012
              • 44
              J4HE the first one thats on the list
              • Caleb
                Smokin IC's
                • Feb 2013
                • 645
                So does the 13v test point not come up at all or was it low? It looks to me as if that feedback circuit is working.
                • lively
                  • Sep 2012
                  • 44
                  it reads 0.000
                  • lively
                    • Sep 2012
                    • 44
                    thats where i stopped and said ok what am i missing .. i need help, i tested all the way to R1684 (470) one side is ground and the other had 15.6vdc the last point i cannot find on board is CL1670
                    • lively
                      • Sep 2012
                      • 44
                      and that is a replacement board from shopjimmy.com that i just got last friday
                      • Caleb
                        Smokin IC's
                        • Feb 2013
                        • 645
                        was your original board the same? You would be better off looking for L1674 and L1675 as cl1670 is just a junction or test point not a part. I will give you a great tip someone gave me if you hit control F on your keyboard in adobe reader it opens the find tool and you just type in the part you are looking far and it highlights it for you each time it appears in the document, just hit the arrows to advance or go back
                        • lively
                          • Sep 2012
                          • 44
                          yes the old one has same reading and has 15.6v at c1670
                          • lively
                            • Sep 2012
                            • 44
                            is there a way to jump this out to bring the set up >?
                            • Caleb
                              Smokin IC's
                              • Feb 2013
                              • 645
                              In my mind that means it unlikely to be the main board causing the trouble. That error maybe a red herring, what haven't you replaced so far? we know for sure the ss was bad as it was shorted yes? I think that just leaves the sn board, you resistance checked it correct? it may have a fault beyond a relay or switched fet and not show until it comes up. I think maybe run through these steps one more time just for giggles. Edit just noticed this one has a control board hiding behind the main, may need to look that one over as well.
                              6) Disconnect (SN2 connector)
                              Is TPVSUS (SN2, pin #1, 191V) on SN Bd. shorted to chassis Gnd?
                              yes, shorted = SN Bd. N/G
                              not shorted = go to step #7
                              7) Reconnect SN2 and disconnect (SS11 connector)
                              Is TPVSUS (SS11, pin #1, 191V) on SS Bd. shorted to chassis Gnd?
                              yes, shorted = SS Bd. N/G
                              not shorted = Power ON TV, and check TPVSUS (SN2, pin #1) for 191V before shutdown
                              If no output, = SMPS N/G
                              If 191V OK is before shutdown, SN Bd. may be defective (can not be sure)
                              Reconnect SS11 Connector
                              8) Is TPSN1 (14V) shorted to chassis Gnd?
                              not shorted = go to step #9
                              9) Measure resistance across C909 & C959 (146V across cap.) on SN Bd..
                              If resistance is only a few ohms across either capacitor, the SN BD. is defective.
                              Im off to bed for the night, check back in the AM
                              • lively
                                • Sep 2012
                                • 44
                                roger thanks for the help .. i will run through and report back
                                • lively
                                  • Sep 2012
                                  • 44
                                  all is good and if i understand correctly the manual is stating to check across each cap c909 - 1.6MEg ohm c959- 18MEg ohm and both fluctuate up and down with i switch leads .. but across the 2 i have 146vdc as stated ... looking forward to the reply .. thanks again
                                  lively
                                  • Caleb
                                    Smokin IC's
                                    • Feb 2013
                                    • 645
                                    Does the control board have the blinking led on it? have you tried swapping in your original power board? Since you have 2 power and main, I would try both combinations of old and new. Did the power board stay up with the lvds unplugged? Running out of ideas here.
                                    a) Unplug LVDS Cable (40 pin connector) from Main to Digital "D" Bd. (D5 connector) behind Main:
                                    This will eliminate the Main Bd., and see if the SMPS will power ON automatically, and remain ON.
                                    Plug the AC Cord to power (do not push the Pwr Key on the TV) and see if the SMPS will power ON.
                                    If the SMPS powers ON and remains ON, then the Main Bd. should be tried. If the SMPS continues to shutdown
                                    then resistance checks (#1-#9) below should be done.
                                    • lively
                                      • Sep 2012
                                      • 44
                                      no blinking lights and when i unplug d25 and others stated i plug the set up and hear the relays click and heat sinks are getting warm .. i mean only thing i havent replaced is the SN board .. lol what the hell ? this thing should be powered up by now right >?
                                      • lively
                                        • Sep 2012
                                        • 44
                                        i ordered the SN board , thats the only one left and if that don't do it then i will upload a tannerite explosive ending to this $160.00 project , but if that makes it come back to life then ill just return the other boards and be out the return shipping
                                        • Caleb
                                          Smokin IC's
                                          • Feb 2013
                                          • 645
                                          Yeah I would think it would work, but Ive had a couple in the past that I gave up throwing money at. I would ship all the boards back and eat the restock fee at least you wouldnt be throwing money away, save the tannerite for the cracked panels.
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • blazzelia
                                            MBP A1286 820-2915 green light only, no start
                                            by blazzelia
                                            Hi guys,
                                            I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                            09-30-2024, 07:20 AM
                                          • jheunne
                                            A1466 macbook no boot green to orange light help
                                            by jheunne
                                            i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                            in first image there is 0v out for lcd
                                            https://ibb.co/5XppmpkH
                                            in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                            https://ibb.co/fdJkbJs8
                                            06-10-2025, 10:52 PM
