LG 47LV550W audio and back light works / no picture
    Re: LG 47LV550W audio and back light works / no picture
    OK, disconnect the those two cable and test again, if it still shows low Ohms then I would remove that and test it off the board, those readings are very low Ohms.
      Will do after work, thanks.
        On a side note, I have easy access to this part:
        Would it be suitable for testing the board?
          That should be fine, the T-CON max current is 1.26A, Inrush is 5A.
            Ok transistor is now changed and voila voltages are now normal, 11,9v at TCON fuse when TV on and 0v when off. But. Picture is as you can see. First one both ribbon cables plugged and others only one.
            Measured following volts at TCON, normal TV show on HDMI1:
            P_VDD: 16,57v
            GMA1...7: Varying 14,4v-10,5v
            GMA9...18: Varying 8,6v-1,1v
            VCC: 3,29v
            VDD: 16,68v
            VGL: -4,94v
            UC1: 0v
            VGH: 4,66v
            VST: -4,93v
            VGH_EVEN: Varying -5v-5v
            VGH_F: -4,94v
            GCLK1...6: Varying -3,7v-(-3,8v)
            VCOM: 6,98v
            Z_OUT: 8,36v
            VCOMRFB: 6,97v
            GIP_RST: -4,94v
            VGL_1: -4,94v
            VGH_ODD: Varying -5v-5v
            VGH_R: 4,66v
            E0: 0v
            GST: 0,01v
            MCLK: 0,2v
            GCLK: 1,03v
            VCORE: 1v
            VIN: 11,84v
            HVDD: 8,25v
            SOE: 0,26v
            VST_IN: 0,01v
            OPT_N: 0v
            VCOMLFB: 6,98v
            PDL: 1,64v
            H_CONV: 0v
            What do you think, TCON or panel damage?
              OK, that is good to know, I wonder that may be the problem in the T-CON or the driver ICs (on the flex PCB of the LCD glsss panel).
              I will let TOM66 chime in on those voltage readings on the T-CON, he knows lots more than I do about the T-CON.
              By the way, good job locating that MOSFET on the board.
                Thanks alot for your help, couldn't have made it this far without you.
                  In Bud's picture, at post #12 there are test points at the (far)right bottom of the T-con.
                  Those are the test points, that you have to measure.
                  Basically, they have to decrease in value, as you measure toward left.
                  I had on mine some test points, where I have measured 0V, which it was weird.
                  Write them down and post them here.
                    I still have the 42" TV and this T-con board looks very familiar, it may be the same part, maybe even the mainboard is the same.
                    My TV has sound, but it seems like one of the panel's tab is unbonded(lifted) from the glass.
                      Yeah I measured them and they are the test points GMA1...7: Varying 14,4v-10,5v
                      This was with IPTV hooked. Will check without signal at some point.
                        They were as you say decreasing from right to left. So does this indicate that the problem is not the TCON? I'll take a video after work but those lines change on screen when there's varying picture source.
                          Hi Masba,
                          Did you try contacting LG in Finland about finding a local Authorized Service Provider or LG itself to provide you with some technical assistance for the 47LV550W?
                          Their number is 0800 0 LG (0800 0 54 54)...IFV
                            You should list the GMA reading in this format:
                            GAM1: xxV
                            GMA2: xxV
                            GMA18: xxV
                            Vgh, Vgl, Vst_in do not look right either, hopefully TOM66 will see this thread soon.
                            BTW, LG is not going to do anything but trying to sell you a new TV, it will not provide service info either.
                              Below readings are with no input:
                              GMA1: 14,43v
                              GMA3: 14,32v
                              GMA4: 13,58v
                              GMA5: 12,50v
                              GMA7: 10,57v
                              GMA9: 8,60v
                              GMA10: 7,93v
                              GMA12: 6,21v
                              GMA14: 4,24v
                              GMA15: 3,17v
                              GMA18: 2,45v
                                Here's a short video with no input plugged in: http://1drv.ms/1tu9SDP , I think there's some kind of "screen saver"/no input detected type of thing moving.
                                Also plugged computer to it and playing video makes lines move and shift the, seems like depending on how much contrast difference there is (you cant really see it properly in the video): http://1drv.ms/1sQAI88
                                  Here's another video where you might see abit better; http://1drv.ms/1sQE7DO
                                    Those readings look good.
                                    I personally, I would take the screen apart, at least to see the tabs, to see if anything looks bad there.
                                    I'm thinking Windex damage(corrosion).
                                    Only after that, I would order other boards.
                                      Thanks for the tip, is there something special to note while taking it apart? Or better yet a step-to-step tutorial so not to do any damage?
                                      Budm mentioned that Vgh, Vgl, Vst_in dont look normal. What would be normal voltages for those?
                                        From what I have read in these forums it seems that problem might be low VGH voltage. Apparently it should be atleast same as VDD?
                                          See post 4 from tom:
                                          https://www.badcaps.net/forum/showth...vgh#post489591
                                          Tom66:
                                          VGH = about 20 to 30V
                                          VGL = about -5V to -10V
                                          AVDD/VDD = about 14V to 16V
                                          those are the key ones, all measured with chassis ground as negative."
