Emerson BLC320EM9 A
  • Tedybear
    • Sep 2014
    • 104
    Re: Emerson BLC320EM9 A
    I'll look them up and figure out a parts list.
    Sorry about the delay. Had to tear apart a VCR and clean the belts. (Old Hitachi with all the bells and whistles. Things built like a brick &hithouse..can't kill it)
    Thanks again for the help. I'll start ordering in the parts that I'm 100% sure I fried, and from there see if I can figure out the rest of the power issues.
    S-
    • Tedybear
      • Sep 2014
      • 104
      All fixed. Many thanks goes to ShopJimmy. Some of the board level parts are no longer available unless I want to buy in heavy bulk.
      So the main board got replaced, everything assembled, and it functions great!
      S-
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Glad you got it working, just curious what parts you were having difficulty sourcing?
        Liberating magic smoke one part at a time
        • Tedybear
          • Sep 2014
          • 104
          I got stuck when researching the zener diodes. Everything else I could find fairly quick. Most of the zener diodes kicked up obsolete and no way to order them in. (Unless I wanted to order in larger amounts off eBay.) By the time I finished up a base line order of the hard parts with shipping costs factored in--it was almost a wash to just order in the main board from shopjimmy.
          S-
          • Caleb
            Smokin IC's
            • Feb 2013
            • 645
            As long as you know the voltage zeners can be direct replaced with any other zener of same voltage and dissipation. I usually order 10 at a time but 22v, 26v and 36v seem to be the ones I use the most of. You can also get an assorted pack off ebay with a bunch of different values. But I understand if this is a one off tv repair your probably better served with a board replacement
            • Tedybear
              • Sep 2014
              • 104
              Well, if I did this more often then once every month or so it seems. I got lucky so far.
              One 50" Samsung DLP repaired the light tunnel. The wife is using it in the living room. (probably the best picture 1080p that I have ever seen on that Samsung)
              The 62" Mitsubishi? Sold it within a week of repairing it. Just repairing the faulty wiring to the bulb and repairing the speaker wiring.
              Picked up another identical 50" Samsung DLP for my home office. Family said faulty light tunnel, dim picture and a 'ghost' around the edges. Pulled the set apart and gave it a full cleaning. All it needed? Replacement 125w bulb. (We had an extra one from the other set.) The old bulb had almost zero reflective material left in the bulb. I checked the bulb life timer as it was the factory bulb left in the set. Well over 12,000 hours and counting. So that set is in my office with a fantastic picture as well.
              And the Emerson. If the set runs flawless through the burn in period? (I leave it running for about a week just to ensure it does not crap out) I'll probably list it on the C-List for about 80 or so.
              I do not do a lot of flipping of things, but most people see these TV's as disposable and at times I can pick things up to repair and resell. (I love the thrift stores for that reason)
              I can see picking up more assorted packs if I did this more often. Truth be told there are about 6-8 people in my area that scour the classifieds for tv's and electronics to repair. By the time I get a lead on a cheap one to repair? It's normally El'Goneo'
              S-
              • saimom
                Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
                by saimom
                Hello everyone!
                Please help me determine which microcontroller was in this place.
                Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
                Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
                They did not take photos before the intervention
                The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
                Maybe someone has a photo of this piece,...
                12-17-2024, 08:51 AM
              • survivalbloke
                Lenovo Yoga C940-14 - will not power up each morning until resetting BIOS
                by survivalbloke
                I've got this laptop here which is presenting very odd behavior. It works perfectly fine except every morning, it won't power up. Power button does nothing. Reset button on bottom also doesn't seem to have any effect, but if I disconnect the battery, hold the power button for a few seconds to drain capacitance, when I connect the battery back, I can power on. It will go through RAM training as normal, and eventually boot into Windows. The laptop will work fine all day long, but the next morning - the problem is there again.
                Any thoughts?
                06-23-2024, 09:51 AM
              • Davi.p
                Reduce the size of photos please..
                by Davi.p
                Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
                05-16-2024, 12:53 AM
              • chzuck
                HP ZBook 15 G3 Freezes When Picked Up
                by chzuck
                I have an HP ZBook 15 G3 that has developed a problem. If picked up by the lower left hand corner the screen freezes. nothing responds. The only way to shut if down is to hold the power button down. I can restart and it will work fine until it is bumped or picked up on the left lower side. Looking for some trouble shooting ideas, please.
                I have eliminated by battery by disconnecting and running on AC power.
                11-01-2023, 08:14 AM
              • magik20
                Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
                by magik20
                I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
                I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
                The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
                04-30-2025, 04:46 PM
