LG OLED77C2PUA CUSQLJR Does not turn on - solid standby light with one blink.
  • Chris24
    • Feb 2014
    • 57
    Hello, been a while since posting and always appreciate this forum and the help.
    Picked up an LG OLED77C2PUA that does not turn on.
    The standby light does come on when plugged in. Pressing the on/off button on TV (or LG remote) the red light turns off for 1 second and comes back on steady. I took off the back panel and tested the power supply. When pressing the power button, the 20V and 12V to Mainboard spike to 19.9 and 11.9 for a few seconds then slowly drop back off. Can tell the supply is coming on for 2-3 seconds. The 12V to TCON also spikes to 11.9 then drops back to 0. The two 23V to TCON remain at 0 with pressing power button.
    Disconnecting two LVDS TCON --> Panel and nothing changes.
    I disconnected the lower cable from TCON --> Mainboard and got results:
    TV powers on and provides audible LG power on tune. The panel stays black, however, there is a single half inch multi-color band on right edge of screen (left if looking from behind fyi). Further inspection with flashlight and TV off reveals tiny hairline crack in bottom right corner - 2 maybe 3 mm in size. Also dark spot here when powered on again, with the multicolor band (lower cable to MB disconnected). Can get the band to flicker with light pressure on panel here as well.
    Checking PS to MB and now every pin gets expected (3.3, 11.9, 19.9 etc.) and stays that way, Tcon gets 12V, and the two TCON 23V are also good. Think PS is good but happy to post pin results if needed.
    Disconnecting the LVDS from TCON --> Panel one at a time: left no change. However with the right out, the left side of panel (right side from behind) comes on with white/grey vertical bands.
    Had already ordered a new TCON online from ShopJ before discovering the hairline crack so installed that, and got all the same above results.
    Reading this forum, and not fully discouraged by the crack due to its tiny size and proximity to corner, I also disconnected the TCON EVDD (that wasnt getting 23V originally) on PS side just to see. Nothing changes with the TCON--> Mainboard cable in, however, with it out, and the right TCON--PANEL LVDS out, the entire screen lights up white/grey vertical bands across entire screen, with some distinction along the right edge vertically (above hairline crack), and now horizontally bottom (along hair line crack).
    In this state - the screen also stays lit even with power on/off cycling.
    So - my assumption is bad panel and can part out the boards?
    Any chance the MB is also having issues? There does not appear to be a red Optical/Audio light.
    Any chance the tape trick on panel LVDS could work (I did some testing without results).
    Thanks in advance for any assistance. I know thats a lot and wanted to give a comprehensive description. Will post some photos.
  • Chris24
    • Feb 2014
    • 57
    Power Supply
    TCON
    Main Board
    • Chris24
      • Feb 2014
      • 57
      Multicolor Band (TCON --> MB bottom cable disconnected)
      Screen fully lit (EVDD --> TCON Disconnected, TCON --> MB disconnected)
      • EazyBone
        • Jun 2023
        • 1419
        • United states
        • Anything I can do with my hands
        A goner I have this tv
        • Chris24
          • Feb 2014
          • 57
          Thanks Eazy, too bad, it is a nice one.
          Assuming because of the panel, so I’ll part out the boards, remote etc. Let me know if you need one! 🤣
          • EazyBone
            • Jun 2023
            • 1419
            • United states
            Haha put em on eBay, I think im good. Looks like it took damage. Was this one you picked up or was it yours
            • Chris24
              • Feb 2014
              • 57
              just a pick up - looked like a great opportunity.
              The hairline crack is super faint, can only be seen with a flash light at the correct angle - or with the MB disconnected
              • ChristianBr01
                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                by ChristianBr01
                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                04-23-2025, 01:48 AM
              • borjawil
                Standby light - no picture LG 50pj350
                by borjawil
                LG 50pj350
                Got it not working. Plug it in, standby light (red light) is on i believe. Push the on/off button and it goes off, then will come on, and slowly fade away.
                I am linking the service manual. I followed the flow chart and with tv plugged in, haven't hit the on button, I check the voltages at power board. I'm not getting 17v any where. And only get 5v at the 3rd to last pin of p301. Flow chart says to just replace the power board. Rather not spend $80+ when I can replace a resistor for a few $.
                I have visually inspected for signs of issues and don't see...
                02-18-2026, 01:09 PM
              • brithepi2k
                Sony KD-65XE8596 no standby light
                by brithepi2k
                I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                cheers...
                09-06-2025, 02:22 PM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
              • alro7779
                Samsung UN70TU7000FXZX A two-times flashing standby light loop with no image.
                by alro7779
                Hello, everyone!
                A friend of mine gave me a 70" Samsung TV that does not show image after pressing the power button... It's in a loop with the standby red light flashing two times while the TV tries to power on with a startup sound. You see, it occurs to me that I could try keep learning how to repair TVs out of this device, so I'll share some pics I took after taking the back cover out; I noticed that someone tried to repair it (or did it at some point) because I found a small power supply glued on the metal cover by the mainboard (3.3v IN and 13v OUT). The idea here is checking...
                04-03-2026, 01:26 PM
