Qe49q60rat Vertical bars
  • porfyriadhs
    • Oct 2023
    • 106
    • Greece
    I have a Samsung QE49Q60RAT TV that came to me with an on/off (boot loop) problem.
    While troubleshooting, I tried the tape method on the panel ribbons to isolate the fault.
    I noticed the following behavior:
    With one ribbon cable connected, the TV powers on and shows a picture, but there are vertical bars/lines on the left side of the screen.
    With the other ribbon connected, the behavior is different (no picture / unstable).
    This makes me suspect either a panel/tab bonding issue or a T-CON/panel driver fault, but I'm not completely sure.
    I’m attaching photos for reference.
    Any advice or suggestions would be appreciated. Thanks in advance!
  • porfyriadhs
    • Oct 2023
    • 106
    • Greece
    • snirsnir
      Samsung QE65Q67AAUXXH (65" QLED) - Bootloop, no logo, no hot components found
      by snirsnir
      I have a Samsung QE65Q67AAUXXH (2021 QLED, 65").
      Panel: CY-QA065HGSV1H
      Main board: BN41-02844A (BN94-16448X) - T-CON integrated, no separate T-CON board.
      SYMPTOMS:
      - Immediate bootloop on power-on - backlight flashes on for ~1 second then shuts off, repeats endlessly.
      - No Samsung logo, no picture at any point.
      - Sound never plays.
      WHAT I'VE DONE SO FAR:
      1. Disconnected both 90-pin ribbon cables from mainboard → TV powers on, backlight stays on steady. No bootloop. Confirmed mainboard and PSU...
      04-23-2026, 06:10 AM
    • x_orange90_x
      Samsung UN46C8000XFXZA vertical bars/horizontal lines
      by x_orange90_x
      I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
      The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
      09-04-2023, 12:09 PM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • jmartins
      LG 55UC970V-ZA: vertical bands/lines appear after ~2 seconds, then clear, repeating
      by jmartins
      I have an LG 55UC970V-ZA (around 10 years old). The picture is normal right after power-on, but after ~2 seconds vertical bands/lines appear across the screen. Then it clears again, and the issue repeats in a cycle (roughly every 2 seconds).
      Symptom (repeatable):
      - After power-on, the picture is normal for about ~2 seconds.
      - Then vertical bands/lines appear across much of the screen.
      - It happens on everything, including the LG boot logo and the TV’s own menus/OSD, built-in apps, and all HDMI inputs.
      - Power-cycling (unplugged...
      01-10-2026, 07:58 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
