Philips 55pus7304/12 stuck on boot logo
  • porfyriadhs
    • Oct 2023
    • 106
    • Greece
    Hello friends I need your help. I have a Philips 55pus7304/12 stuck on boot logo. Tried update via usb with no luck maybe wrong file dont know. Any one who knows about this situation will be helpfull. Thanks
  • porfyriadhs
    • Oct 2023
    • 106
    • Greece
    • porfyriadhs
      • Oct 2023
      • 106
      • Greece
      • William1967
        • Nov 2017
        • 231
        • Netherlands
        There is a recovery file available that you can find here: https://****************/uc?export=d...TtdTjXEh_Fp_Dx
        • porfyriadhs
          • Oct 2023
          • 106
          • Greece
          So do i open the file and paste to the usb ?
          • porfyriadhs
            • Oct 2023
            • 106
            • Greece
            I insert the usb and install the software. Waited for some time and the the tv shut down. I remove the usb and I open from Main button. It stuck on logo with red stand by light flashing
            • William1967
              • Nov 2017
              • 231
              • Netherlands
              Download the software, create an empty FAT32 formatted USB drive of not more than 8Gb, unzip the file to the USB drive , place the USB in USB port 1 of your tv, connect the power and wait, on screen you should read "update in progress..." the update can take some time so be patient. It could be the tv resets once but do not take action, wait untill the tv shows a white circle with the text "erasing" , after that the tv reboots and your tv is ready.
              • porfyriadhs
                • Oct 2023
                • 106
                • Greece
                Thank you very much
                The tv is working 🙂🙂
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • Teban1306
                  [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                  by Teban1306
                  Hello everyone!
                  I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                  System Information:
                  • Model: Lenovo ThinkPad T14 Gen 1
                  • Machine Type: 20S1S4E600 (Intel i7 variant)
                  • Current BIOS: N2XET42W (1.33) - Latest version
                  • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                  What I'm trying to achieve:
                  Replace the default "LENOVO" boot logo with a custom image during POST.
                  🔧 What I've tried:
                  09-14-2025, 11:49 AM
                • fredyjbi
                  Please help me, my friend Dell 5420 La-k491p bios recovery failed stuck on logo, thank you
                  by fredyjbi
                  Please help my friend Dell 5420 La-k491p rev 2.0 vpro ST.BZD1JQ3 laptop turns on but error bios recovery failed stuck on logo thank you...
                  05-08-2026, 11:34 PM
                • odie34
                  TCL 55S451 Stuck on Logo Screen But Working Otherwise
                  by odie34
                  I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
                  So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that...
                  04-25-2026, 03:40 PM
                • Marcus3235
                  Qubo Dash Cam Pro X Stuck During Boot: SigmaStar SSC335R + W25N512GV SPI NAND
                  by Marcus3235
                  Note: I am not a professional electronics/embedded engineer. Everything I've done so far has been learned through YouTube videos, datasheets/forums, and guidance from AI. I've been proceeding cautiously, measuring and documenting each step, and have deliberately avoided writing/erasing the NAND or making irreversible changes.
                  Qubo Dash Cam - SigmaStar SSC335R stuck at "Load BL from SPINAND"
                  I'm trying to recover a Qubo dash camera that stopped booting. Qubo support told me the unit has gone bad and recommended replacing it, so I'm investigating...
                  08-09-2026, 08:45 PM
