Dynex lcd 2 sec to black issue
+ More Options
Posts
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Dynex lcd 2 sec to black issue
    No I haven't. I wasn't sure if I could do that or not cause the backlight gets 24v but does have a bl on. What would psu be. The power on circuit.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      So I tried forcing the backlights on while the main was unplugged. I jumped 5v to ps on an 5v to bon and the back light lit up for 2 sec and then shut off. So I have no idea what to check next. Anybody got any input. Getting frustrated with this one.
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        So I looked at the panel schematics under the inverter section and all the conditions the inverter needs to see to be functional are all present on the inverter when it's off. The only thing I can think of is somethig with those bulbs. But I just don't understand it and I don't know where to get any.
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          I called ccfl warehouse and they don't sell any other kind of bulb other then the regular probe ends. So basically I think I might be screwed on this one.
          • Locutor13
            • Oct 2013
            • 61
            Hi, I have the same Dinex DX-46l150A11 with the same problem of getting the 2 sec the black issue after replacing the same ccfl (not original) of T6. Has anyone been able to find a solution?? Please Help.
            • Locutor13
              • Oct 2013
              • 61
              I was able to remove the protection of the backlight by shorting the pin 14 "Timer" of the chip U201 to ground as shown in the attached picture. Also you will see next to the chip a series of jumpers J213,J219,J209,J208,J212 & J211 each one for smalls caps or resistors and each has two small semi circles.
              If you know the right combination you can match the settings of the ccfl according to the specifications of the protection by shorting some of those semi circles.
              Be aware that removing the protection should be done only for testing purposes as if posses a serious fire hazard.
              • sgcampion
                Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                by sgcampion
                My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                10-24-2023, 09:39 AM
              • Stephen
                MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
                by Stephen
                This is not a flexgate issue.
                The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the...
                06-10-2021, 09:09 AM
              • Verlengsnoer
                Toshiba C660 Black screen/reboot issue in combination with Nvidia
                by Verlengsnoer
                i have a Toshiba c660 laptop, with i5 and nvidia
                When installing the driver for the nvidia gpu, the screen goes black in a few minutes, and the laptop restarts itself
                when i uninstall the nvidia driver, the laptop works fine but choppy video because of the missing video driver.
                i tryed a random bios backup, just to see if it is a bios based issue, tryed to reflowed the nvidia chip, but nothing seems to fix te nvidia/reboot issue
                hope some of u have some tips (im not technical in measuring voltages or other hardware based...
                04-05-2022, 01:20 PM
              • sew333
                Please help, I have an issue with new monitor Aorus FI27Q (black dots dropping down v
                by sew333
                Hello.
                First my pc.I have Gigabyte Rtx 3090 OC ( stock ) and 10850K stock ,32gb ram.
                Issue is only on 1920x1080P with 165hz. On 1440P with 165mhz is fine. On 1920x1080P with 144hz is fine. On 1920x1080P with 165mhz i can see on screen small black dots flickering vertical.
                If i wanna catch screen its not visible or clip. So i post screen and i added from paint. Just very small flickering black dots on vertical position. Screens not working. Happens only in 1080P with 165HZ. Visible on desktop too when i am very close.
                Just found on reddit somebody had the same...
                03-10-2021, 05:13 PM
              • pc1staid
                Dell Latitude E7270 shut down issue
                by pc1staid
                Hi Guys and Gals,
                I have a really strange issue with the above titled Ultrabook.
                Quick spec's, i7-6600 with intel HD520 graphics, 8GB DDR-4 RAM, 256GB M.2 SSD, 12" screen, Wifi, Finger print, NFC.
                Use of the laptop is out on sites, remoted into a NAS just for files, software installed Win10, Office 2019, Teams, Printer software. Thats it, sledge hammer to crack a walnut.
                OK, the issue. 4 days prior to me getting it, just after login, approx 15 secs the laptop will shutdown. Not as in power off/cut, no restart, it goes through the shut down procedure. This is...
                12-19-2020, 01:17 AM
