Sony XBR-55X900F EMMC Repair
  • Konner
    Hello, I picked up a free broken Sony XBR-55X900F. Motherboard number 1-983-249-31. I figured it would be a fun project to fix. When I plugged this TV in it was completely dead and had no power light. I followed this guide to help me diagnose the problem https://www.youtube.com/watch?v=4afrEbS5mZw. I have quite a bit of experience fixing other electronics, but not much with repairing TVs. I initially thought it was going to be a dead power supply, however after quite a bit of digging I suspect that the emmc is likely corrupted. I had 1.8v and 3.3v going to the emmc. With the motherboard removed I supplied 3.3v to the power_on, bl_on, and tcon_on and got the pattern test screen where it flashed through the different solid colors. I decided to pull the emmc off the board to read it. I don't have much experience with reading and flashing emmc. However the emmc seems to be healthy at 10%-20% device life time used. I've tried looking for another emmc dump for this TV and and was unsuccessful. Does anyone else have a dump for this emmc, how do I know what part of the firmware is corrupted, and what do I have to flash to fix it?
    This is the emmc dump from my board https://****************/file/d/1XMI...ew?usp=sharing
  • kevin_allein
    • Dec 2023
    • 122
    Hi, may I come back to your test showing the LCD test screen ?
    You write, that you only supplied 3.3v to the power_on, bl_on, and tcon_on pin. But those are all pins of the power supply connector - correct ? Did you not have to apply some signal to the TCON itself to get the pattern test screen where it flashes through the different solid colors ?
    • hallc386
      Can you share us the dump? thanks in advice.
      • BigPete
        Panasonic LED TV Dead after EMMC dump
        by BigPete
        I recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
        The dump was successful and the program finished without errors.
        I used a XGecu T48 to do the dump.
        I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
        One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
        I also shorted out the crystal of the adjoining ECU together and at one...
        03-15-2026, 03:08 AM
      • saghi88
        i need eMMC Dump for Sony KDL-55W805C
        by saghi88
        The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
        This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
        does anyone have the EMMC dump file?
        Model: Sony KDL-55W805C
        Mainboard: 1-980-805-31
        EMMC: SK HYNIX H26M52103FMR
        Display-Panel: T550HVF06.0
        07-04-2025, 02:11 PM
      • Morosan Dimitrie
        Sony KDL 55W-955B Sony EMMC dump search :)
        by Morosan Dimitrie
        Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
        KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,...
        06-08-2024, 04:13 PM
      • 5m44p1x
        Looking for Sony KD-55X750F EMMC dump
        by 5m44p1x
        The TV falls into boot loop several minutes or hours after power on, I'm thinking it's the EMMC issue, and want to have a try from there. Is there anyone who got this one and willing to share it with me? Million thanks!
        Model: Sony KD-55X750F
        Mainboard: 1-982-454-11
        EMMC: SK HYNIX H26M52208FPR
        08-01-2025, 12:26 AM
      • D1964
        Sony KDL46w905A EMMC dump
        by D1964
        Hi Can anyone supply a EMMC dump for the above model please
        10-05-2025, 08:11 AM
