Samsung le32r73bd
  • sordids999
    • May 2013
    • 2155
    Samsung le32r73bd
    tv has backlights and sound but no picture voltages seem fine possible tcon ?
    or has anyone else come across this problem before ?
    thanks
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: Samsung le32r73bd
    check this out. worth a try:
    https://www.badcaps.net/forum/showth...710#post467710
      Most common fault on these causing this symptom is blown fuse on the T-con board.
      • sordids999
        • May 2013
        • 2155
        Should I be getting 12v either way on the tcon fuse because I'm getting 0.00 volts ?
          12V on both ends, red on either end of fuse, black on chassis
          • sordids999
            • May 2013
            • 2155
            5.3 volts on both ends tom
              OK, can you supply a picture of the T-con?
              5.3V is OK for this earlier model.
              • sordids999
                • May 2013
                • 2155
                here you go
                  Try checking regulators UP2, UP4, and U14
                  • kasfamily
                    • Aug 2014
                    • 772
                    • Russia
                    U14 should be 2.5 volts
                    • sordids999
                      • May 2013
                      • 2155
                      Up2 5.30 3.27 0.00
                      up4 5.35 3.50 2.25
                      u14 5.50 0.85 2.25
                        If kasfamily is right, (I have little reason to doubt) then it looks like U14/UP4 may be bad.
                        What is the part # printed on them?
                        (N.B. You should use a good soldering iron to remove and replace them IF they are determined them to be bad. You can also use a hot air gun.)
                        • sordids999
                          • May 2013
                          • 2155
                          very difficult to read but ..
                          UP4 NIKOS L1117DG XA5B21A60
                          U14 MM06100B 25 F614
                          UP2 L1117L6-33
                            OK, looks like U14 is bad (UP4 is probably OK)
                            See here:
                            https://www.badcaps.net/forum/showthread.php?t=38665
                            • kasfamily
                              • Aug 2014
                              • 772
                              • Russia
                              A small error-U14 - MMC6100B-25 replacement AMS1117-2.5
                              • sordids999
                                • May 2013
                                • 2155
                                thanks guys
                                • sordids999
                                  • May 2013
                                  • 2155
                                  Hi
                                  Replaced the regulator screen came back on but now im getting this picture so it looks like more things are wrong with the tcon board ?
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    Gamma issue or you didn't reseat the LVDS cable right. Try reseating the T-con TFT cables (4) and the LVDS cable from main to T-con. Also clean the contacts too.
                                      09-07-2024, 05:50 AM
                                    • max789
                                      Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                      by max789
                                      Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                      I made the following tests:
                                      1. Disconnected the main board from Power Board = backlight works.
                                      2. Connected the main board and disconnected the T-Con = backlights does not work.
                                      So I ordered a main board from Ebay also BN41-02156A but from...
                                      01-18-2024, 06:56 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
