Service Menu Device Lock in LG UHD Hi3751V352
  • kintaro77
    • Jan 2026
    • 8
    • Nigeria
    Hello brilliant minds!
    I was busy hacking my LG android TV to remove the tons of restrictions and Bloatware that came with it, when I discovered the service menu by entering INPUT 2580 on the remote. However I accidentally clicked the DEVICE LOCK option and now my TV is asking me for a password. I have literally tried every code I have come across on the internet and nothing works. I don't know what the default password for this is.
    The TV is a LG 50UQ70 (specifically the smart models using the Hi3751 board). It is very likely a Chinese board. The board is specifically Hi3751 V352. I think the model is also called "bigfish".
    I will attach pictures of the software info.
    The menu you can see is from before the device lock got activated. I cannot access it now because of the keypad displaying on the screen.
    Any help or insights would be appreciated. Thanks.
  • nomoresonys
    • 12370
    • U.S.
    Not sure, maybe 0313 for reset then it might accept 0000 or 1234 as default.
    • kintaro77
      • Jan 2026
      • 8
      • Nigeria
      Tried this but it didn't work
      • mrsat
        • Aug 2022
        • Nederland
        https://www.techwalla.com/articles/h...rd-on-an-lg-tv
        Try this 7777 maybe it works?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4889
          • Italy - Milan
          post photo of main board, bright, no shadows, have you got an eprom programmer?
          • kintaro77
            • Jan 2026
            • 8
            • Nigeria
            Here are pictures of the board. No I don't have the eeprom programmer or UART tools just yet.
            To update, I opened the board recently and found out it is actually a ZP.255E.802R01 . I have searched for the usb update firmware all over the internet with no success, and all the key combinations I have tried so far didn't work.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4889
              • Italy - Milan
              unfortunately there is only an emmc that stores data and retrieveing it via cheap programmers is difficult, i see no exit way here..
              have you activated the debug mode before doing the "patatrac"? If yes try some adb commands, but usually no root - no joy...
              • kintaro77
                • Jan 2026
                • 8
                • Nigeria
                I was using shizuku and running adb commands before the device lock happened. But I have to manually activate debug mode and shizuku each time the TV starts and this password panel prevents me from doing that. So I can't run adb commands now.
                • kintaro77
                  • Jan 2026
                  • 8
                  • Nigeria
                  Originally posted by mrsat
                  7777 didn't work either 😥
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4889
                    • Italy - Milan
                    I worry that if you do not resolve you have a well heavy hammer for constructions and you give at the appliance what it deserves
                    • maker2023
                      • Nov 2023
                      • Algeria
                      try 0532 it will be work 100% if it fail enter source+2580 search for export cusdata or skydata depend on your tv board soc use ysb disk to store the imported file skydata open it on your computer search for boardSoc.ini in the bottom of the file you can find superpassord=0532 good luck
                        Back Again?
                        • 32841
                        Nothing LG about this TV unfortunately, I didn't know that they were rebadging Made in China stuff, I guess they are now. That's disappointing.
                        I think the manufacturer may be ZVT.
                        https://www.made-in-china.com/showro...2f803bbf3bf71/
                        So that may help you find the unlock code.
                        For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
                        Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
                        • Diah
                          • Feb 2013
                          • 6763
                          • Boardview and Schematic Bot
                            LCD LED TV Service Menu Codes
                            TCL LED TV Service Menu Code
                            LG LED TV Service Menu Code
                            10-31-2024, 03:58 AM
                          • 1centchips
                            a2159 not able to revive, disconnects at step 4 of reviving
                            by 1centchips
                            Goes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
                            History, came in with severe liquid damage and bubbly motherboard Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
                            Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
                            Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]:...
                            04-01-2026, 11:38 AM
                          • alltvrepairs
                            Jvc Lt-65VU3000 reduce backlight from service menu
                            by alltvrepairs
                            I have just replaced led set of this vestel tv due to age.
                            I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                            Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                            Thanks again....
                            09-20-2025, 05:03 AM
                          • intercepter
                            JVC LT-32CA120 service menu
                            by intercepter
                            I have JVC LT-32CA120
                            Board:Vestel 17MB171
                            I need rotate screen.It is possible in service menu and how to enter service menu?
                            Thanks.
                            12-10-2024, 10:29 AM
                          • tusiime
                            How to access Vizio m652i-b2 service menu
                            by tusiime
                            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                            09-15-2023, 09:57 AM
