50" Vizio Plasma Tv red snow on start up
  • ohmmy
    • 182
    Have this plasma tv that I replaced all caps on psu that solved a flashing standby light.
    Been using it fine. Today with ambient temperatures on the chillier side and not used the tv till dinner time, noticed blotchy snow like dots of red scattered on the screen.
    Decided to keep it on and maybe it needed to warm up? Well within a few minutes the dots went away and picture is normal.
    Question, is this a normal thing for plasmas? Especially older ones? It's a 2007 model.
    Re: 50" Vizio Plasma Tv red snow on start up
    Is the panel inside made by LG, Samsung or Panasonic (Matsushita)?
    • ohmmy
      • 182
      Hmm I'm not sure. Didn't notice when I had it apart. The model is VP50
      • ohmmy
        • 182
        So is this a normal trait for plasmas when tv is first turned on?
        Should I check Va and Vs voltages?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Older LG Chassis sets do suffer from this condition called, Mal-Discharge Its where the various pixels mis-fire and dont light or when they light when they are not supposed to.
          I believe its all to do with the gas-pressure in the panel.
          A Cold panel will tend to have a lower pressure--therefore, easier to ionise and make light.
          As to why the gas pressure lowers isnt due to leakage, but rather inclusion or diffusion over time into the dielectric and phosphor layers in the panel--This occurs over several thousand hours use.....
          LG came up with a Control-Board update to accomodate the problem, but in your case, it doesnt sound like a huge issue as the panel warms, the gas pressure returns to within expected limits--fault disappears.....
          --When we are thinking of gas 'Pressure' in the panel, we are still looking at a near perfect vacuum, There's only a very small amount of Xenon gas inside the panel, if there was the same amount as atmospheric pressure (13.5PSI) then the panel wouldn light at all....
          TELEFIX
          • ohmmy
            • 182
            Ok nice to know. Yeah it happens especially when the room is cold and within a minute or two the screen literally snaps into the proper color.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              If it gets much worse--There are things that can be done, but as its such a small issue, I would just run as it is....
              It may or may not get worse--or sometimes, Ive seen it actually get better,--why or how I have no idea.....
              TELEFIX
              • ohmmy
                • 182
                So now I'm noticing randomly scattered red dots after it's been on for a while but they're not as noticeable as when first turned on and it's cold in the room.
                They're mainly in the middle of the screen and most visible in blacks
                • caphair
                  • Nov 2011
                  • 1249
                  Interesting.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    You could try to alter the pot meters a LITTLE bit clockwise but this is normally with green sparkles ( at least this fixed a LG plasma that i was working on ).
                    Also , try disconnecting 1 of the buffer boards and see if the sparkles are still visible. If so try the other buffer board. ( Screen will be half black/half picture. )
                    If you notice any difference then you know where the fault is and the buffer board is slowly giving up….
                    • SS454
                      vizio e650i-a2 backlight flashes then turns off
                      by SS454
                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                      panel: au optronics T650HVN05.4
                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                      08-20-2020, 03:57 PM
                    • mrtek
                      Vizio M65-C1
                      by mrtek
                      Hi.
                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                      07-14-2025, 07:28 PM
                    • r-p
                      Maldischarge-link that fixes it with replacing caps
                      by r-p
                      Starting this thread because Capkid doesn't seem to be reprogramming controlboards anymore (LG 60PZ950 with red maldischarge) and my game-plasma also has maldischarge (Hitachi 42PD3200). So I will grasp at straws to keep them running. I am extremely bad at throwing stuff away.
                      Is there any merit to this link?
                      Very short version: Specific caps seem to loose their capacitance and/or increase their ESR. This may cause the maldischarge. Replace them with better/bigger/newer ones and problem solved.
                      From the limited knowledge I have on the subject, I think...
                      01-21-2020, 05:16 PM
                    • howardc64
                      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                      by howardc64
                      Failure Symptom
                      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                      Where is the short?
                      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                      05-27-2025, 02:56 PM
