Samsung LE37A656A1F
  • del3165
    • May 2014
    • 24
    • United Kingdom
    Samsung LE37A656A1F
    Hi I have a Samsung LE37A656A1F. The problem is with the colours or no colour. I have attached some samples of the problem. Hopefully someone can help.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Samsung LE37A656A1F
    The whiteness is more likely a faulty gamma chip.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • del3165
      • May 2014
      • 24
      • United Kingdom
      Will that be the t-con board
      • Shinju
        • Mar 2014
        • 1239
        YES, if its an AUO Optronics made panel its almost always the AS-15 G U F ect. chip on the T-con.
        If you are good at SMD soldering its a pretty simple task.
        Take the panel apart and snap photo's of all the boards, also the T-con will be located at the top or bottom middle of the TV and usually covered by a metal shroud. SOME panels do not have a T-con as they are intergrated into the mainboard or TFT driver boards that are permanently attached to eh LCD TFT display and cannot be repaired.
        • del3165
          • May 2014
          • 24
          • United Kingdom
          I have removed the t-con board. The chip that I think is the
          Sg-15 has no writing, it does look a bit burnt. The T-con board is a t370hw02 v6 does anyone know the exact AS-15 chip number for this board ie G U or F etc
          • flocko
            • Nov 2012
            • 1121
            The AS15-F can be used as a replacement for all G/U and F chips Flocko
            • del3165
              • May 2014
              • 24
              • United Kingdom
              Thanks just need to brush up on my soldering skill.
                They are not identical but they can be used to replace each other on AU Optronics boards. AS15-F was used to replace AS15-U on a Sony board of mine, without issue (AUO 37" 720p panel.)
                To test your board you will need a digital multimeter.
                Board must be installed in TV and fully connected. Make sure to screw it down. Play a video or still image on the screen.
                Then in the top right corner of the board you will see a set of points VGAMA1, VGAMA2...
                Test each of these points (usually there are 18 or 22) and report back the voltage on each point with the number of the point..
                For example:
                VGAMA1 ... 1.03V
                VGAMA2 ... 2.45V
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I recommend using ChipQuik to aid in the removal of the old chip if it turns out to be faulty. It made the one i did a couple of weeks ago very easy.
                  • del3165
                    • May 2014
                    • 24
                    • United Kingdom
                    VGAMA1. 14.78v
                    VGAMA2. 14.72v
                    VGAMA3. 10.3v
                    VGAMA4. 9.64v
                    VGAMA5. 9.34v
                    VGAMA6. 7.27v
                    VGAMA7. 7.21v
                    VGAMA8. 0.15v
                    VGAMA9. 0.15v
                    VGAMA10. 0.16v
                    VGAMA11. 0.15v
                    VGAMA12. 0.14v
                    VGAMA13. 0.1v
                    VGAMA14. 0.11v
                    This was tested with now tv home screen on.
                    • del3165
                      • May 2014
                      • 24
                      • United Kingdom
                      I was going to order ChipQuik looking for a uk supplier. Last time I removed a chip like this I used hot air gun. The ChipQuik looks a lot easier.
                        The chip is definitely bad (the VGAMA are wrong) so replacing it should be all that's needed.
                        Personally I prefer a hot air gun for removing the chip.
                        • joe025
                          • Oct 2014
                          • 10
                          • germany
                          Hallo i got a same problem with my samsung LCD.
                          My T-con Board is T370HW02 V6
                          Backlight Ok, Powersply OK,
                          Igot Sound but the picture is Black with coulured stripes.
                          I have checked the VGAMA Voltage:
                          VGAMA1. 15.2v
                          VGAMA2. 15.2v
                          VGAMA3. 10.69v
                          VGAMA4. 10.00v
                          VGAMA5. 9.69v
                          VGAMA6. 7.57v
                          VGAMA7. 7.50v
                          VGAMA8. 6.66v
                          VGAMA9. 6.60v
                          VGAMA10. 10.45v
                          VGAMA11. 4.65v
                          VGAMA12. 4.00v
                          VGAMA13. 0.2v
                          VGAMA14. 0.2v
                          Is the the AS15-F broken?
                          Thx for your help.
                            Yes, bad AS15-F. Replacing it should fix the problem.
                            • joe025
                              • Oct 2014
                              • 10
                              • germany
                              Thats a picture of my screen.
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                Not saying that your Gamma chip is good--with those voltages--
                                But That image of half a black panel, the rest with vertical lines looks more like the panel itself...
                                Does disconnecting one then the other of the screen-tabs from the T-Con (While off) and trying again give say half a good picture....?
                                TELEFIX
                                • joe025
                                  • Oct 2014
                                  • 10
                                  • germany
                                  Hey thx for your answer.
                                  I want Test it tomorow an tell what happend.
                                  • joe025
                                    • Oct 2014
                                    • 10
                                    • germany
                                    I have unpluged the left first:
                                    then the right one:
                                    Is this a Panel problem?
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      Looks like it.
                                      • joe025
                                        • Oct 2014
                                        • 10
                                        • germany
                                        Should i try to repair the t-con?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
