Vizio E320VL - No Power, No 5v Standby - DEAD PSU??
  • eagle00799
    • May 2012
    • 322
    Re: Vizio E320VL - No Power, No 5v Standby - DEAD PSU??
    So I ordered the kf5n50's from SJ and the fuse from Digikey I will let you know how this goes after the parts get here.
    • eagle00799
      • May 2012
      • 322
      Just letting everyone know I had success fixing this tv. I replaced Q0465R Resonant Power IC. (U101), the cement fuse, and 4 power mosfets on the bottom of the board. Can't thank you enough Budm and everyone else that makes this site so great. Thanks again.
        Glad to hear and thanks for the repair follow-up.
        • mnorton
          • Nov 2015
          Hi Guys,
          I have a problem like these in this post.
          When it does work it works fine. when it lose power, it will not turn back on. I have nothing that turns on. I replace with a known good power supply board it it did not solve the problem.
          what should I be looking for
          • Newbie62
            • Apr 2015
            • 27
            • usa
            #65
            Originally posted by budm
            OK, check fuse F601? WHITE RECTANGULAR BOX close to the 450VDC large cap to see if it is OK first, if it is then:
            you can test the power supply board by itself first without having other boards connected to it, you will be measuring the DC Voltages on the two legs of the cap C104, C105 which are in the hot DEADLY side of the circuit so care must be taken.
            You will have to flip the board so you can easily work on the bottom side of the board, make sure not to touch anything or let the probes slip on you.
            We also need the P/N of U101 SMPS IC so we can look up the spec sheet for it.
            You should pug the board into GFCI outlet for safety.
            I have one of these tv's that had no logo light and no voltages whatsoever on the output pins.
            I replaced the ICP250 with a MPC71 I had on one of my junk parts boards and the tv fired up !
            The value of the ICP250 IS .16 - .25 ohms 5 volts, I replaced it with .22 ohms 5 volt.
            THANK YOU BUDM !!!!!
            • countryguy45
              • Jan 2017
              • 5
              I have this set I have 5 volts stand by power and can cross out the pins and get the 12 volt as well, I ordered a new main board and still have nothing....Think I got ahold of a bad main board
                • 12276
                • U.S.
                #67
                Are all the voltages correct on the powersupply board?
                • countryguy45
                  • Jan 2017
                  • 5
                  yes voltages are correct but nothing not even the amver vizio is coming on
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • x_orange90_x
                    Vizio E550i-A0 no power, no standby light
                    by x_orange90_x
                    I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                    11-20-2023, 09:49 AM
                  • funkmunk3y
                    Vizio M65 C-1 power supply dead - NO standby voltage
                    by funkmunk3y
                    Hello!
                    I was given this Vizio because it would freeze up after a few minutes of operation. There were no obvious burns marks or failures. When I was checking the power supply - I slipped & shorted it (tiny crackle & spark) at one of the 12 volt pins - now the entire board is dead & has NO standby voltage @ the connector to the main board.
                    The fuse at the power input is reading good - the main caps are reading in the 160's & all the diodes read good except one (D9103 - pictured) - but it only reads bad in circuit - I pulled it & it tests o.k.
                    11-29-2020, 02:58 PM
                  • Andreas_de
                    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                    by Andreas_de
                    Hello!
                    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                    04-12-2025, 10:38 AM
