Vizio LED xvt553sv
+ More Options
Posts
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • What?
    Vizio SV422XVT blinking amber/white power light
    by What?
    Good day, hope all are healthy and cozy. I could use some help with my malfunctioning Vizio with a blinking power light. I have narrowed the problem to the main board but not sure what to do next. I guess it would be good to start with what I have done.
    Problem:
    I have no image, no sound, blinking power light. (left it plugged in overnight and it was still blinking the following morning). I tried the Vizio recommendations (hold power button for 30 seconds, press reset button, check the outlet is live)
    Power Board:
    I am getting 5v only. I have unplugged...
    04-27-2020, 06:21 PM
  • brad2157
    Vizio E70-E3 Two white vertical lines
    by brad2157
    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
    Replacement main board - Boots up fine, but starting...
    12-13-2021, 05:11 PM
  • EazyBone
    Vizio d650i-c3 freezing
    by EazyBone
    This Vizio doesn't freeze at startup. Not that problem
    This Vizio will go into an app like YouTube and work and a very bad picture rate and freeze on videos pretty quickly. But will freeze up in all the apps. Plug a Roku stick into it and it works flawless without video buffers etc. Is there a solution to this freezing issue with Vizio's? It's at latest firmware. I figured they just suck, but factory reset and firmware didn't fix.
    09-16-2023, 08:20 AM
  • brucetv
    Vizio oh ohhhh Alert Px65-G1 & Px75-G1
    by brucetv
    For any unfortunate soul that purchased this Tv you might want to know about a premature panel failure problem it has many times within the 1 year warranty or just past it. Imagine that. A top of the line P series with all kinds of fancy dancy features and the panel isn't worth a damn. In fact we see more panel problems on the P series than any other series Vizio year after year since they came out. Shame on you Vizio and consumers please quit buying into this crap. On the Px65-G1 the Tv will boot up with a faint Vizio V logo first then get the usual Vizio logo for about 5 seconds and then go...
    03-11-2021, 08:26 PM
