Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Vizio TV M70-C3 blink codes
  • Bjs
    • Jun 2014
    I was given this TV with little info. Was told that it didn't have a picture. Upon powering it up it displayed the Vizio logo and the menu was able to be displayed. I connected an antenna (OTA), did a channel scan which completed and the picture has been fine for days. The only issue is it has an initial blink code of 23 upon power off, followed by a 19 about 75 seconds later which then repeats the 19 code four more times. I haven't been able to find the process for entering the service menu nor do I have the service manual for this model (I do have the E60-C3 and E70-C3 service manuals but they don't make any reference to the service menu). I did a factory reset, but the blink codes remain. I've searched the forum for info but didn't find any relevant info for this model. Firmware is latest (V1.5.16-UHD). I believe the main board probably has the BGA issue with one or both chips, but it hasn't yet failed of me, but it probably will if given enough time and power cycles.
    Anyone know what the blink codes mean or how to invoke the service menu for this set?
  • EazyBone
    • Jun 2023
    • 1389
    • United states
    I've never heard of a 23 or 19 blink code for any tv lol that's too many blinks.
    But yes this set has bad main board bga all the time.. I could only assume it's this because it's so common
    • Bjs
      • Jun 2014
      So maybe a corrupt EEPROM? It's very repeatable. Never changes. If I could get to the service menu, I may be able to clear it.
      • Boardview and Schematic Bot
        LCD LED TV Service Menu Codes
        TCL LED TV Service Menu Code
        LG LED TV Service Menu Code
        10-31-2024, 03:58 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • JaquesPratt
        Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
        by JaquesPratt
        I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
        This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
        07-16-2024, 01:04 AM
      • CHARRIS100
        Vizio M65Q7-H1 – Black screen with sound, LED backlight diagnosis & panel removal question
        by CHARRIS100
        I’m working on a Vizio M65Q7-H1 that stopped displaying a picture but still powers on and plays audio. When the TV is turned on, the VIZIO logo appears very briefly (a split second) and then the screen goes completely dark. I did the flashlight test and can faintly see the logo during startup. Audio continues to work normally, and the TV still responds to the remote.
        I contacted ShopJimmy for advice and was told the symptoms point to a failed LED backlight, so I purchased a full replacement LED strip set for this model:
        Vizio LB-GM3030-GJVIZIO6510X18VB20-R-S...
        02-03-2026, 03:20 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
