Lg LED 42lm580y-tc no picture
  • bil99
    • Sep 2014
    • 17
    • romania
    Hello everyone
    i have a 42" Led 42lm580y-tc with no picture and no sound (sound only works when playing Through direct audio in but i"m not sure it counts)
    the TV had a small water damage incident before it stopped working as a few drops of water dropped on the top of the screen and fell all the way to the bottom , the TV worked for a little while and then stopped.
    the red led blinks twice when powering it up.(but i wasn't able to find what that means in error code)
    the backlight works fine but there is no picture or manu screen or sound.
    the only place i found water damage was at the bottom on the left part (that i"m not sure how its called) that is connected with a ribbon to the T-con and with 3 ribbons to the LED screen (there are 2 of the one is called left and one is called right but they seem identical only assembled the other way around)
    i checked all the fuses on the power board and they were fine.
    i checked the logic board and it seems to have the 12v and 3.3v (vcc) in all the places i checked
    the T-con gets the 12v when the tv is on
    only problem that i was able to find is that one of the resistors at the bottom (R104) was severely damaged from the water damage and showed no resistance and also showed 5v on one pad but 0v on the other so i replaced it (poorly) and now passes on the 5V (also checked on the via that's after the pad and all looks fine)
    this happened 3 months ago and i didn't have time to try to fix it because i also study and work part time and finally now i have a vacation.
    i will attach the photos and if you need a better picture of anything please let me know and i will upload it asap .
    also have the schematics if anyone is interested and i will attach it below
    i can measure anything you"ll ask or replace almost any part on the board
    thank you guys in advance :-)
  • bil99
    • Sep 2014
    • 17
    • romania
    Re: Lg LED 42lm580y-tc no picture
    tested all the voltages on the power board and all looks in order
    then i tried disconnecting each one of the cables connected to the the Tcon and here are the results
    can anyone please help me
    thanks
    • bil99
      • Sep 2014
      • 17
      • romania
      60 people watched and no replay ...
      am i doing something wrong ? can't anyone help me ?
      • Ugur87
        MacBook Air M4 A3240 Brand New Water Damage no Image
        by Ugur87
        I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
        08-28-2025, 01:09 PM
      • edugimeno
        Stagg sms12p audio amp has water damage
        by edugimeno
        Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
        I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
        There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
        There is only one signal wire connecting the first boards...
        05-24-2025, 06:00 AM
      • Joel Ohana
        Lenovo IdeaPad 3 15IAU7 that suffered water damage
        by Joel Ohana
        I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
        Symptoms:
        • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
        • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
        What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
        03-06-2025, 11:25 AM
      • abajor
        A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
        by abajor
        Like title says A2141 came in with Water Damage, customer desperately wants the data.
        The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
        I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
        That said after cleaning up the...
        12-21-2024, 07:16 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
