panasonic power supply problem
  • erskine
    • Jan 2014
    • 20
    • barbados
    good morning ,
    I am working on a panasonic LCD model #TC-32LX85X.
    The problem is , when i first plug it in and turn it on it worked for hours.
    Then it shud down and the relay is constantly switching on and off, have to leave it unplug for a while for it to come on again , but same thing happens after a minutes .
    The power supply number is TNPA4484 (3) (p).
    took out the power board and have it connected to a main board and it still does the same thing.
    was able to bridge the relay , and the 12v , 24v and 2 other voltages working fine, .
    problem seem to be either the 5v standby supply or the relay curcuit need help or a schematic,
  • tw2005
    • Oct 2011
    • 6458
    Re: panasonic power supply problem
      Check to see if the standby Voltage is steady or it is going up and down.
      • erskine
        • Jan 2014
        • 20
        • barbados
        Sorry for not getting back here . The 5volt supply is stable once the tv is on buy fluctuates once the relay starts clicking . will get back to it tomorrow and see what i find
        • erskine
          • Jan 2014
          • 20
          • barbados
          checked the 5volt supply and its stable for a while , then it slowly drops , and then the relay starts to click on and off
            by sam_sam_sam
            03-31-2024, 02:12 PM
            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
            by sam_sam_sam
            I was working on this CNC machine today found no keyboard functioning no control relay powering on
            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
            Found shorted diodes on main controller relays there are 3 of them that...
            01-07-2023, 05:43 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
