Kdl-48w590b turns on fine then turns right off and starts blinking red
  • ransome
    • Nov 2013
    • 20
    • usa
    Kdl-48w590b turns on normally for about 30 seconds thens shuts off with blinking light. I have 2 of these , I took out the power supply and both main boards and put these in the non working tv , same result
    any ideas?
  • ransome
    • Nov 2013
    • 20
    • usa
    Re: Kdl-48w590b turns on fine then turns right off and starts blinking red
    It blinks 6 times after shutting off
    • anmol
      • Mar 2012
      • 73
      • India
      This is back light problem.
      wbr
      • ransome
        • Nov 2013
        • 20
        • usa
        wbr
        Is it repairable?
        • marce002
          Macbook A1465 works fine Linux but turns off in MacOS
          by marce002
          Hello
          I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
          Formating and installing does not work because it also turns off.....
          But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
          So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with...
          02-02-2022, 05:43 PM
        • tec3000
          Sony LED 65X9005A shuts down after few seconds - looking for help
          by tec3000
          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
          03-20-2024, 07:29 AM
        • ravi_1617
          Lenovo B540 ,Starting Problem
          by ravi_1617
          Hello !
          Model Lenovo B540
          Board Details 09244-1
          LA14 DIS MB
          48.4DMO4.01.1
          This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
          when connected CMOS dont start.
          3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
          One more thing i want to mention ( by mistake i started at...
          10-14-2025, 02:08 AM
        • retrorepair2
          Dell E5470 LA-C631p - Short removed now turns on but no post/display
          by retrorepair2
          Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
          Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
          09-25-2025, 07:12 AM
        • Caimano
          hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
          by Caimano
          MB G7AD-2G DAG7ADMB8D0 REV D
          Processor i5 8265U
          AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
          Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
          Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
          02-06-2024, 10:14 AM
