LG 55LD520 Backlight Inverter common issue repair
  • Sevenqi
    • Jul 2011
    • 292
    Got this TV, tried to turn on, the screen flashing less than a second then went black, then power off. But when press any button, it show picture same short time then black again. This is obvious the backlight issues.
    LG LCD TV uses master and slave inverters, this symptom looks like the one part of the inverters working but other part didn't.
    Open the back cover and saw the connectors between upper and lower inverters for the mater inverters were fired, really bad look.
    So I cut and soldered out/clean the connectors, only keep the 4 wires (for the inverter feed back), and connected them with 4 proper size wires.
    Powered on, backlight came back and TV works good. Hope this can help some one has same issue.
  • skcatch
    • Oct 2014
    • 4
    • US
    Re: LG 55LD520 Backlight Inverter common issue repair
    Cool, I'm currently working on the same model TV.
    • Ceramiclover
      • Nov 2015
      Tried this repair but TV turns right off. Any guidance on testing?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yep seen this before on a Sharp inverter, do you have a DMM ?
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • ugamazing
          by ugamazing
          12-17-2024, 07:05 PM
        • rookieme
          imac 21 2011 109-C29557-00 vga common issue
          by rookieme
          So I've noticed that some imac 21" 2011 vga has a common issue that make the system reboot of just shut down.
          This is not a gpu chipset issue, cannot be fixed by replacing chipset and sometimes it appears after replacing chipset [due to usually faulty 216-0810005].
          So far I have tried reballing vrams, replacing Q601,Q611 & C838.
          Has anyone faced and fixed this issue?
          03-02-2021, 03:43 AM
        • Dreadnought
          L40DIGB20 Logik 40" inverter/backlight issue.
          by Dreadnought
          Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
          Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
          02-08-2021, 12:28 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
