bn44-00338b
  • DenK
    Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
    by DenK
    Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
    1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
    12-06-2024, 01:29 AM
  • dudochnicht
    Dell Inspiron 7520, LA-8241P mainboard problem, power on black screen
    by dudochnicht
    Hi, i have a Problem with my Dell Inspiron 7520 LA-8241P Mainboard.
    When i start it, all LED's turns on but the display is black.
    Shortly after starting I noticed a click on the mainboard but don't know where it came from.
    I have tested it with the i5 and after the click the laptop goes off but with the i7 the laptop stays on after the click .
    The Dell Inspiron 7520 supports the i7
    What I've already done:
    - start without RAM and it beeps 2 times
    - start without bios battery and it beeps 5 times
    - Press D on start,...
    10-24-2021, 06:43 AM
  • DemonBG
    Samsung QN82Q60R - locks up / Crashing / Unresponsive
    by DemonBG
    Picked this one up a few days ago. QN82Q60R. Screen works perfectly and sound works but after booting, the unit randomly becomes unresponsive to input (though whatever is on the screen will continue to play).
    Tried standard reset - no improvement.
    Tried service mode reset - No improvement
    Service menu is difficult to navigate as the unit regularly crashes / locks up which means i have to restart the set.
    Something i have also not seen before is that sometimes (not always) when i enter the service menu, i get an error "ERR by empty version Data....
    03-16-2024, 09:49 PM
  • kandj1@talktalk.net
    Panasonic TX-43JX600B
    by kandj1@talktalk.net
    Can any of you, much-cleverer-than-me, experts help me bring a TV back to life, please?
    It has a no picture or sound problem, even though the red standby light switches to green when switched on from the remote. I've tried a hard reset, but no improvement. Also have removed the rear access panel and physically & electronically (multimeter) checked fuses (x3) plus all capacitors, diodes and resistors - all of which appear fine. When plugging it back into the mains, with the rear access panel still removed, I can see the back light IS working but the screen remains black and unresponsive...
    09-07-2025, 06:52 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
