JVC VCR HR-S9850 fast FF/REW & Stop problem
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 337
    • D12
    Hi, when tape is doing fast FF or fast REW and I hit stop, right reel stops almost instantly, and left reel is still spinning for second or maybe half second. And you can hear that crackling when tape stops and it wrinkle a bit on the side where pinch roller is I think before it. Then I do a little REW or FF to tight the track back because in that moment it became loose on pullies. I can't find out what's going on and how to fix it, I tried to replace that left brake arm but still same, everything is clean in vcr, new pinch roller, belts, felts. Any idea what this problem could be ?
    Here is video of it maybe it will explain better.
    https://i.imgur.com/SLDyabt.mp4
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 337
    • D12
    I dissasemble the whole bridge million pieces(didn't have time to take picture while doing it), and clean everything and assemble back again and aligned according to manual. And now, everything is working as it should. Don't know exactly what the problem was, probably some misalignment in timings somwhere, but when I was lookling and comparing to the other bridge everything was same...
    https://i.imgur.com/HmpJhvi.mp4
    • x_orange90_x
      Seven Leagues Slot Machine stop button issues
      by x_orange90_x
      I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
      The issue now is the Stop buttons are intermittently...
      02-12-2025, 10:01 AM
    • cook
      HP Power Supply 6632A: Fast Mode vs Normal Mode?
      by cook
      FAST MODE vs NORMAL MODE
      I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
      I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
      06-07-2020, 05:32 AM
    • SevenOFF
      Denon AVR-X4000 – Fast red blinking after 2nd relay
      by SevenOFF
      I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
      According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
      Here’s what I’ve done so far:
      • Fully opened and cleaned the unit (a lot of dust inside)
      • Removed and visually inspected the AMP board → nothing visibly damaged or burned
      • Testing is done with
      06-18-2025, 09:54 PM
    • Jazoe
      Acer Nitro 5 AN515-55 (LA-K862P GH51M) - Turns on for a split second, fans spin then stop, lights stay on (Not BIOS/EC)
      by Jazoe
      I am working on an Acer Nitro 5 AN515-55 with motherboard model GH51M LA-K862P.
      The Symptoms:
      When I press the power button, the cooling fans spin up for a fraction of a second and immediately turn back off. However, the keyboard backlight remains on, the power LED stays solid blue, and the charging LED remains solid orange (indicating it detects and charges the battery normally).
      There is no image on the screen, and the laptop appears stuck in an early power state.
      What I have tried so far:
      1. Power Drain & Hard Reset: Disconnected the main battery
      07-07-2026, 02:20 PM
    • Boardview and Schematic Bot
      TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
      FF Series (Very Fast Acting), 0603 Size
      Features
      ● Very fast acting at 200% overload current levels
      ● Low DCR
      ● High inrush current withstanding capability
      ● Fiberglass enforced epoxy fuse body
      ● Copper termination with nickel and tin plating
      ● Halogen free, RoHS compliance and lead-free
      Applications
      ● Notebook computers and tablets
      ● Digital cameras
      ● Memory cards
      ● Toys
      ● Bluetooth earphones
      ● Portable electronic devices​...
      10-07-2024, 05:50 AM
