Sanyo P42840-00 no sound thru HDMI only.
  • kevinm34232
    • May 2012
    • 1884
    I have a customer that has this issue, with main board N7AL. According to him, the sound works through all other inputs except HDMI. My first thought was the 100 pin HDMI proccessor, but then I was wondering if there was a seperate circuit for the audio from the HDMI, does anyone know?
    This board uses this audio amp
    https://cdn.badcaps-static.com/pdfs/...5e7ccae8e7.pdf
    Would that only be for the digital audio, HDMI and optical, or all audio?
  • ChaosLegionnaire
    by ChaosLegionnaire
    09-13-2022, 09:02 AM
  • japlytic
    Not all TVs can handle surround sound on a HDMI input
    by japlytic
    With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
    So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
    08-31-2022, 10:09 PM
  • hugocarmo
    Sanyo VHR-D4710G VCR no sound.
    by hugocarmo
    Hi again guys.
    Today I have a problem with this Sanyo VCR.
    I bought it online, It worked sometimes.
    I recap the Power supply and it started working fine.
    Image is perfect and all digital effects too.
    All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
    I have no sound on playback, on tuner, or aux in.
    On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
    On one of the sound processing...
    01-23-2024, 12:58 PM
  • CraigR
    lg 46LD550 HDMI no sound
    by CraigR
    I got in a LG with no signal on HDMI ports so I replaced the HDMI IC and now I have picture but no sound on just the HDMI the other inputs are working fine for sound. Any ideas? Would the amplifier ic have anything to do with just HDMI?...
    10-05-2022, 01:13 PM
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
