Sanyo DP46841-00 No power, no lights, no picture
  • kage
    • Sep 2014
    • 22
    Re: Sanyo DP46841-00 No power, no lights, no picture
    Originally posted by lookimback
    Take a couple pics of the analog board too. Front and back.
    posted stats for IC. this was to hopefully get your attention.
    • kage
      • Sep 2014
      • 22
      Also 1.1V standby out of IC6720 on the digital main is good.
      • kage
        • Sep 2014
        • 22
        So this is really odd. Pin 1 on the control board (power button) reads 3.3 volts instead of 5 volts like the diagram indicates it should be. The RC board shows 5 volts like it should but they are both coming from the same feed so... wth?
        • kage
          • Sep 2014
          • 22
          Another part of the manual says it should be 3.3v. Grr.
          No one interested in chiming in?
          • bmeyer
            • Mar 2015
            • usa
            #45
            trying to fix a sanyo #dp46841-00 will not turn on I only have 5 volts present no 12 or 24 volts
            • ShatterMasters
              • Oct 2017
              • 14
              Having same symptoms, did you get this resolved?
              • francoservo
                FRANKITOO
                • México
                #47
                Hello friends, I have the same problem and I found that the flash memory (SPI) was corrupted, mount a similar one and the waiting light came on, who can share the .bin file?
                • lotas
                  • Jan 2016
                  • 4611
                  • Russia
                  #48
                  Post your original, non-working dump here, I’ll try to fix it.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                    03-31-2024, 02:12 PM
                  • liquidzorch
                    Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                    by liquidzorch
                    Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                    10-18-2024, 05:19 PM
