Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
i mean the Caps area which have low R. need to measure V on them
Not sure what you're referring to. Can you explain more?
Summary (correct me if I'm wrong): Problem either with TCON (it's getting the proper voltages - and replacement is on the way) or Panel (not fixable) - The best course of action is to replace the TCON and if not fixed, then it's panel. Nothing more can be done on the panel beyond the capacitors checks.
Now when I received the TCON, I'd appreciate the help on the "pairing process" as what was mentioned with green / blue lights don't seems to correlate with my TV
well even the service manual say t-con or panel.. and i think its panel.
So say 19v evdd, the resistance of ~200ohm that's less than 100mA... that seems reasonable. Why would you think they're too low?
Voltage at black connector is roughly 19v, but at the caps that are low, voltage is 1.2v or so... not sure if tcon is limiting power, or if that's expected? Without schematic I guess it's tough for me to assess?Last edited by jason123; Yesterday, 01:41 PM.Comment
Not like you can trust what any of the sellers say!! Sellers lie all the time... they can say "brand new" for a quick sale...so none are trustworthy....the majority say brand new tv and screen damaged during shipping. .. how can you suspect an issue there? it's always 50/50 ... not many available anywayLast edited by jason123; Yesterday, 01:48 PM.Comment
you have another 3 EVSS on buffer boards.. compare them then you know why i said panel
Voltage at black connector is roughly 19v, but at the caps that are low, voltage is 1.2v or so... not sure if tcon is limiting power, or if that's expected? Without schematic I guess it's tough for me to assess?Comment
Lol... when did you know it was 100% panel? We should have stopped at that point, right? Don't get me wrong, I appreciate the help, but I wanted to know if it's TCON Or Panel. If Panel, it's trash as not fixableComment
i wrote at post #13 99,8% Panel.. are you mad because of 0,1% lol.. and i never suggest to try boards... my wish for you and others i am wrong.Comment
No, I am not mad at all...again I appreciate the help... but when we got a lit panel and no hot spots on panel when bypassing error detection, I thought we're still hopeful.Comment
for you and other maybe... on Buffer boards there are COFs and EPROM with VCC 3.3V.. EVSS which we called are belong to EVDD which PSU supply it.. they are running round the panel .. any break or short at cell raw T-CON driver boards will register it as error.. we talked on this before..
Display lit dim white this is first time i saw over OLED.. but it could EPROM damaged or its VCC.. if you try other T-CON and the issue same... don't trash it.. just cut the metal over buffer boards we will fix it.
No before we started the troubleshooting the TV would start with White LED then turn to 5 blinking red (2 separate LEDS) not sure what i did, but white no longer turns on nowComment
by standalone test of course it will not, cause MB disconnected... but by DIY t-CON error pins.. it should lit on specially after the reset you did, check the Kabel as its like ribbon one from both sideComment
So out of curiosity, I measured the voltage across the exposed capacitors on the panel. Help me understand the result. I'm getting almost an exact mirror from the left 2 to the right 2. So if there is a short, I would expect to see something different? What in these results tells you it's a panel problem? Again, just trying to understand your reasoningComment
But not tcon... right?
And what in the reading is telling you something is indeed wrong in the panel? What should the reading be? You said compare and you'll see it's panel. Trying to understand that statement
ThanksComment
by matwanHello,
I have problem with SONY 55X90J. After several check status is as below;
1. Running power board as stand alone:
TCON_12V =~ 12.6V
EVDD V On Max 24V= 19V.
2.Running power board with TCON as stand alone:
Effect as below, attched.
3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
"I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
Best regards.... -
Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
Observations:
1) I noticed I was not getting... -
by GoodCapDudeHi everyone. First post on Badcaps!
I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot.... -
This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 04:30 AM
by GlavalHello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...3 Photos
- Loading...
