JVC LT-50CF890(c) lines on screen, trying tape method
  • Chrissygizmo
    • Mar 2021
    • 145
    • United Kingdom
    Hi again all,
    I’m busy trying to sort this tv out JVC LT-50CF890 (c) , originally i had nothing on the screen, but after removing the Tcon strips off I got half a picture, now while trying the tape method I have a complete picture but after the boot screen I’m getting lines , I will upload photos & any help would be appreciated Click image for larger version
ID:	3746534 Click image for larger version
ID:	3746535 Click image for larger version
ID:	3746536 Click image for larger version
ID:	3746537 Click image for larger version
ID:	3746538 Click image for larger version
ID:	3746539 Click image for larger version
ID:	3746540 Click image for larger version
ID:	3746541 Click image for larger version
ID:	3746542 Click image for larger version
ID:	3746543 Click image for larger version
ID:	3746545 Click image for larger version
ID:	3746547 Click image for larger version
  • Chrissygizmo
    • Mar 2021
    • 145
    • United Kingdom
    I have tried to edit the title but I can’t seem to do it, it should read-
    JVC LT-50CF890(c) HORIZONTAL FLICKERING LINES ON SCREEN, TRYING THE TAPE METHOD
    • tiki66
      • Jul 2016
      • 59
      • Croatia
      There's nothing more you can do, these panels are known to fail
        • 12306
        • U.S.
        That half picture you got, was it a good one or did it have lines also?
          • 12306
          • U.S.
          I'll throw out some thoughts, Thinking it could be dirty flat cable ends from tcon to panel, bad tcon, maybe bad tab bond.
            • 12306
            • U.S.
            You can try the simple things, never know I guess. Try plugging tv straight into wall outlet if using a strip. No joy, try unplug tv for 5 minutes, press and hold power button on tv (if equipped) for 45 seconds let go, plug tv back in and try it. If you can work the menu try a system update, try factory reset, make sure during test that no hdmi or rca cables are plugged into tv.
            • PNI E.
              Samsung eu75nu8000 no picture after tape method
              by PNI E.
              Hi guys, I write here for help me. I have a Samsung eu75nu8000. The Tv start to turn off and on, and I understand it was a panel problem, because if I take out a ribbon the Tv stay on. I tried the tape method but I have no picture but the Tv now stay on. My question is I have to give up because it s the panel? I notice that the chip vpm2sm it s really really hot, I can’t stay with my finger on it. Do u think all the problem of my panel is due to this chip, or u think it s a death panel and I can’t do nothing?sorry for my English
              11-10-2024, 03:46 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • RetroComputingGrotto
              IBM LTO 7 Tape Drive - Dust Sensors??
              by RetroComputingGrotto
              I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
              I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
              09-19-2024, 01:54 AM
            • Rubenlily
              Samsung QE50Q67TAU - horizontal lines
              by Rubenlily
              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
              I'm no expert but I've done the tape...
              08-16-2023, 01:12 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
