Samsung ln40d550k1fxza
  • triplefour
    • May 2014
    • 1747
    Re: Samsung ln40d550k1fxza
    ok actually i realized the psu and motherboard are good, by hooking up my n64 and changing source till i hear it, and then i used a strong light and i could see the image on the screen, so it seems like my only problem now is getting the backlights to light up. i can see that i am sending 12v to the inverter...hmmm maybe i got lucky and didnt fry anything with that fuse mistake...
    Don't fear the repair...
      Which inverter board do you have?
      http://www.shopjimmy.com/catalogsear...ln40d550k1fxza
      Also check the DC Voltage right at the two leg of the main filter caps when TV is on, it should have >360VDC on the two legs (there are two of them rated at 450VDC).
      To blow a 10A fuse, some thing did blown up and blown open circuits that is why it did not blow your new fuse now.
      • triplefour
        • May 2014
        • 1747
        ok heres some pictures of the inverter, and the connectors on the PSU
        voltages to the inverter:
        pin / voltage
        1 - 4.2v
        3 - 4.2v
        8 - 0v
        9 - 0v
        10 - 12v
        11 - 12v
        12 - 12v
        • triplefour
          • May 2014
          • 1747
          but the 10A fuse never actually blew. something went pop and i assumed it was the fuse but when i actually checked it later, the fuse was fine...so it was something else...but i am getting all the voltages i need to the motherboard and TCON to transmit the signal to the panel but i am not getting any backlight even though the inverter is getting 12v... i guess the pop could have been something on the inverter going bad. but i really have no idea.
          im pretty sure i did check the filter caps while the tv was running and i saw 165v on both of them.
            "im pretty sure i did check the filter caps while the tv was running and i saw 165v on both of them."
            Well, that is the answer, it is not working. As I have indicate in post 22, it should have >360VDC. The PFC Voltage booster circuit is not working, it blew up the first time that why the fuse was blown, you need a new board.
            • triplefour
              • May 2014
              • 1747
              i know you're the expert but do you think theres a chance you are mistaken about the voltage on these main filter caps? 165 seems pretty normal to me from the other tvs ive been working on...can you please explain how u know they have to be > 360v?
              edit: the voltage 4.2 on the low and high is whats the problem, right? that should be 24v and 12v?
              is there really no way to repair the damage?
                "can you please explain how u know they have to be > 360v?" Because it has PFC Voltage booster circuit to raise the 170V to >360VDC. I can see it by looking at the board layout.
                "is there really no way to repair the damage?" Things can be repaired, it just how much time and money you want to spend on it.
                And if you want to learn about PFC Voltage booster, then just do the research on the subject to get some idea what is it is for and how it works, just matter of spending hours, days, years in learning.
                Examples:
                You worked on this one, it also has PFC: https://www.badcaps.net/forum/showthread.php?t=40311
                Also this one: https://www.badcaps.net/forum/showthread.php?t=40044
                Also this one: https://www.badcaps.net/forum/showthread.php?t=39670
                You should start taking some voltage readings and take notes on what you work on.
                  BTW, the high frequency/high voltage on pin 1 and pin 3 (white and blue wires) will be in hundreds of AC volt for driving the primary side of the inverter transformers.
                  http://www.shopjimmy.com/media/catal...40b-bottom.jpg
                  If it was working, your meter would have been blown up.
                  • triplefour
                    • May 2014
                    • 1747
                    aw man....i thought anything going to the inverter was safe...i thought it only went high voltage after the transformers! jeez...good thing i blew up this tv instead of my meter i guess... so what area of the board is the pfc and what components make it up?
                      OK, you are going to have do some research and will learn about the board, see the bottom side of the board in my post 28, you will see SMD ICs, go look up the spec sheet to see what they are and what they do, this is the way for you to learn.
                      • Clydeuk
                        • Jan 2012
                        • 193
                        #31
                        Just an observation based on a previous comment. You suggested earlier that you feel you may have had a working TV if you had only replaced the blown fuse with the correct 3.15A rather than the 10A fuse you tried. That won't be the case. Sure the 10A fuse did not protect the circuit which resulted in the pop and damage to the PFC circuit, however a 3.15A fuse would just have blown. Had there not been a fault on the power supply other than just an open fuse, the set would have worked when the 10A was put in, albeit you would have had no protection for the circuitry and something could have overheated and caught fire etc etc.
                        So you had a short on the primary, which correctly blew the 3.15A fuse. By fitting a higher rated fuse you allowed that higher current to flow, the pop was probably the MOSFET in the PFC circuit blowing a hole, or possibly some print vaporising, the short now is probably gone hence why the new fuse holds, but the PFC circuit isn't working.
                        I do think a replacement board would be the best method as I expect a fair bit of damage will have been done, otherwise you could find yourself in a chicken and egg situation where you replace some parts only to find them blowing again immediately due to other faulty parts still in circuit.
                        • triplefour
                          • May 2014
                          • 1747
                          thank you cylydeuk for your input. what you say makes sense. if it were just about fixing this TV i would definitely order the board but in this case im more interested in using it to learn about the PSU, specifically with this one, the PFC booster circuit. but maybe its a bad one to start with because there may be too many unknowns blown already... i have other PSU's that might be easier. maybe ill just end up selling the motherboard out of this one and be done with it...
                            Well if you want to learn, then you need to get the P/N of those SMD ICs on the bottom side of the board and get the spec sheet and the application notes, those info will explain how each one of those ICs function.
                            • triplefour
                              • May 2014
                              • 1747
                              thanks budm. i will try to do that.
                              • triplefour
                                • May 2014
                                • 1747
                                so i took the board out to study it in detail (try to learn the circuits of this PSU and hopefully others)
                                right away i figured out where that pop had come from.
                                the 2 mosfets near the fuse that are both connected to the same heatsink are totally blown apart.
                                i cant even read the markings on one of them.
                                what do you think will happen if i just replace these mosfets?
                                • triplefour
                                  • May 2014
                                  • 1747
                                  im starting to think they will just blow up again... i need to figure out why they blew in the first place...
                                    Good clear pictures of the bottom side of the board?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      from shopjimmy:
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        Any idea what I should look for?
                                        • Shane711
                                          • 493
                                          Just in case anyone comes here with the same problem, their TV won't turn on. Here is what you need to check. First check to see if the fuses are blown and if they are you might need to replace all these parts but at least check them before you spend any money.
                                          LN40D550K1F / LN40D550K1FXZA / 40D550K1F
                                          Board Part Number = BN44-00440B
                                          Transistors ........... QQI802, QQI808, QP801, QP802
                                          Capacitors............ CM806
                                          Fuses.................. FS801S, FS802S
                                          Diodes................. ZDM805, ZDM806
                                          Resistors.............. RI805, RI806, RP825
                                          Integrated Circuits. ICI801, ICM801, ICP801
                                          For Board Part number BN44-00440A check these parts
                                          Integrated Circuits. UI801, UM801S, UP801S
                                          Resistors.............. RM811, RM823, RP821
                                          Transistors............ MI1801, MI1803, Q1801, Q1803, QP801S, QP802S
                                          Diodes................. D1809, D1811, DM801, DM802
                                          Fuses................... FM801S, FS801S
                                          It would not hurt to just replace all these parts if you do not know how to test them but only if you have tested the fuses and found them to be bad.
                                          NEVER replace the fuse without testing or fixing your power supply, it blew for a reason and will only blow again.
                                            09-07-2024, 05:50 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
