Vizio M420NV - No sound, remote not working
  • BriSpe
    • Sep 2014
    • 4
    My Vizio model m420nv TV recently had the sound go out. I tried to see if I could get sound out of the audio jack, but it didn't work. I switched from the DirectTV box to the DVD player to see if it was an input problem, but it didn't have sound either. After some research, some people reported the audio setting changes in the menu by itself. I tried to check the menu, but the remote doesn't work (fresh batteries), and the button on the TV itself only accesses the quick menu, which only has volume, power, input, and channel options. I tried researching more, but it seems like everyone has video or power problem, which I do not, and their sound is fine. I was going to see if I could replace the main board, but can't find any in stock. I do see the eeprom available, but am not sure if that is the issue. I've also looked into voltage regulators, but am not sure if any are bad (I will list my results below). Does anyone have an idea of what else I can check? Or where I should go from here?
    Thanks,
    Brian
    Voltage Regulator Results (only ones i could find)
    1117 Type
    U2
    1 - 5.24v
    2 - 3.27v
    3 - 2.02v
    U4
    1 - 3.30v
    2 - 1.24v
    3 - 0.00v
    U46
    1 - 5.22v
    2 - 3.29v
    3 - 2.04v
    1084 type
    U3
    1 - 5.21v
    2 - 3.30v
    3 - 2.05v
    7805 Type
    U8
    1 - 5.03v
    2 - 0.00v
    3 - 12.01v
  • fl13lane@gmail.com
    • Jan 2015
    Re: Vizio M420NV - No sound, remote not working
    I had the same issue a year ago the sound would not work. i plugged in a sound bar and had sound. after about 4 months the sound on the TV started working again. not sure why just did. but now the remote stopped working can it be the sensor?
    • ecking767
      • Oct 2009
      • 492
      check the +12v fuse going into the main board. post pictures of your main board
        12V fuse on the main board is OK because the 7805 regulator U8 is getting the switched 12VDC from the power supply OK.
        • Sauktronics
          • Mar 2017
          • 4
          Anyone figure this out I am having the same problem remote wont work and no sound
          • dskall
            • Oct 2016
            • 2905
            • usa
            Post some pictures of mainboard and connectors.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Can you reset your set to Factory Default
              • Shane711
                • 493
                This problem sounds just like the Vizio SV470M. It is possible it could be a bad CPU. Here is the thread for the discussion about the SV470M
                https://www.badcaps.net/forum/showthread.php?t=38602
