Element ELCHS321 has 5vsb and red light but wont turn on
  • triplefour
    • May 2014
    • 1747
    got a Element ELCHS321 from the recycler yesterday for 10 bux.
    when plugged in i see the red LED and i can see 5vsb on the board
    but when i push power, nothing changes.
    heres some pics
    and the voltages on the connection from the PSU to the Mainboard
    pin/name/voltage
    1,+5v,0.83v
    2,+5v,0.83v
    3,gnd,0
    4,gnd,0
    5,bl-on/off,0.02v
    6,dimm,0.83v
    7,gnd,0
    8,+12v,3.2v
    9,+12v,3.2v
    10,+5vsb,5.14v
    11,+5vsb,5.14v
    12,on/off,3.87v
    13,gnd,0
    14,gnd,0
    i dont see any change in on/off or any pin for that matter when i push power button.
    Don't fear the repair...
  • triplefour
    • May 2014
    • 1747
    Re: Element ELCHS321 has 5vsb and red light but wont turn on
    i do see a change in the voltage on pin1 of the button board connector when i push power... there are 3 pins on the connector. 1 is ground. the other 2 show voltage drops from 3.3 to varying voltages depending on which button was pressed. the voltage drops from 3.3 to 0. on pin1 when pushing power.
    seems the motherboard is getting the signal from these pins to turn on but it is not actually listening....
    • triplefour
      • May 2014
      • 1747
      the connector to the inverter has 14 pins also
      the labels are kind of confusing as they dont label each pin individually
      but here are the readings i got on the pins
      1,4.93v
      2,4.93v
      3,4.93v
      4,4.93v
      5,4.93v
      6,0v
      7,0v
      8,0v
      9,0v
      10,0v
      11,0v BRI
      12,0.02v SW
      13,0.85v PWM
      14,0 GND
      seems like pin 1-5 are labeled 24v
      pins 6-11 are labeled ground
      but maybe pin 11 is BRI
      because after that there is
      only
      SW
      PWM
      GND
      • triplefour
        • May 2014
        • 1747
        heres some pictures of the back of the PSU...
        spooky, the main cap still has a charge of 120v after being unplugged for a couple minutes!
        i just checked again and it still has like 55v
        its been like 10 minutes!
        is that a sign of something wrong in the circuit? arent they supposed to discharge a lot faster?
        seems like they do on the other sets ive worked on...
        • triplefour
          • May 2014
          • 1747
          well i think i found the problem!
          after i looked closer at the board i noticed that a gecko had gotten into the TV at some point and got fried under the PSU board and then fell down into the case.
          where he died you can see he rusted some of the case as he decomposed, and on the PCB where he must have initially got fried, theres a row of resistors that are all corroded, probably ruined.
          HAH! believe it or not this is not the first time ive seen this.
          pretty common in hawaii to have critters crawl up and die in electronics.
          i assume they find it when its off and think its a cool place to chill, and then when someone turns on the power, ZZZZZAAAAAPPPP!!!!
          can this type of thing be cleaned and fixed up, or do i just need a new board?
          • triplefour
            • May 2014
            • 1747
            jeez...how can i be sure that it didnt fry the motherboard as well?
            cause it seems like pressing power on the button board should still generate a change in voltage on the on/off pin for the connector that goes to the PSU, shouldnt it?
              1) So far the main board does send out PS_ON (12,on/off,3.87v) to the power supply board but the power supply is not putting out the 24V as needed by the inverter board.
              2) The main board is not sending out the BL_ON (5,bl-on/off,0.02v) (it is labeled as SW (same as BL_ON or Inverter ON) pin on the inverter board).
              Try disconnecting the cable from the power supply to the inverter board to see if the 24VDC will show up.
              11,0v BRI: Analog dimming control, not used.
              12,0.02v SW: BL_ON (same as Inverter ON).
              13,0.85v PWM: This inverter uses PWM Dimming control.
              14,0 GND
              The board looks badly corroded, did you check all the connectors and all the boards for more corrosion? Moisture damaged?
              • mmartell
                • Oct 2013
                • 3189
                IIRC there are two mosfets under the board, one for the 5v supply the other for the 12v. I had the same set and budm helped me troubleshoot it. In mine I had 5v but no 12v, the 12v mosfet was not opening up completely. I see you have a small voltage on your 5v rail so I would check those mosfets - 8 pin soic I think.
                • mmartell
                  • Oct 2013
                  • 3189
                  Search ELCHW321 may help.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4942
                    • New Zealand
                    Clean up all the corroded traces and replace any if destroyed for a start
                    -David VanHorn
                    • triplefour
                      • May 2014
                      • 1747
                      i dont see anything corroded except where the gecko got fried.
                      i tried disconnecting the inverter from the PSU and it didnt change anything.
                      i cleaned up the traces as best i can but no luck... how can i test those components to see which ones are fried? they are tiny SMT capacitors and resistors?
                      mmartell thank you, i am reading your post.
                      are you sure that is the same TV though, or just similar?
                      • triplefour
                        • May 2014
                        • 1747
                        i do have 2 8 leg IC's on the underside... are these the mosfets you speak of?
                        what should i test on them?
                        • triplefour
                          • May 2014
                          • 1747
                          ugh can someone please tell me what im doing wrong and why i can never seem to find the datasheet for anything?
                          1207A - nothing
                          PFLQ - nothing
                          17A06 - nothing
                          PBLY
                          what are the magic google terms?
                          i read all of mmartell's thread but i still dont really understand what i should be looking for. plus my board is different :/ still a noob
                          • triplefour
                            • May 2014
                            • 1747
                            on the 1207A i see 150v on pin1 and 75v on pin 3 but 0 on all other pins.
                            all pins on 17A06 are zero as well...
                            and as usual, cant find a service manual...
                            • selldoor
                              Slow Learner
                              • 7870
                              https://cdn.badcaps-static.com/pdfs/...5fdfffadce.pdf
                              • triplefour
                                • May 2014
                                • 1747
                                ok great but HOW did u find those? please teach me how to fish so i dont gotta keep hitting u up for fish!
                                not that i am in any way ungrateful for these delicious fish.
                                thank you!
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4942
                                  • New Zealand
                                  Part of the trick is knowing which number to search for - one is usually just a datecode which won't turn up anything. If in doubt try each one separately.
                                  If you get a match, download the datasheet and verify that the marking in the datasheet is the same as on your actual IC.
                                  -David VanHorn
                                  • triplefour
                                    • May 2014
                                    • 1747
                                    hmm now i see it in the results i got but i guess im supposed to know that its a pwm current mode controller... all the extra letters around it threw me off...
                                    NCP1207ADR2
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      ok from the datasheet i now see that the voltages i was seeing were on the HV pin and the Vcc pin... but why am i getting zero on all the other pins, and on the 17A06?
                                      in mmartell's thread the IC was a mosfet with a S, D and G but mine is totally different... what am i supposed to look for here?
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4942
                                        • New Zealand
                                        Do you have a scope? You could check for a drive waveform on pin 5. Also check feedback pin to see if it's not causing a shutdown.
                                        If the other IC has no power, find out where it gets power from, it may be it gets switched via something else or the fact it has no power is a clue to the fault
                                        -David VanHorn
                                        • Adogabriel100
                                          Macbook pro A1278 820-2936 No light/turn on
                                          by Adogabriel100
                                          Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                          History:
                                          this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                          A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                          The macbook can turn on with only the battery connected but in fact, dosent charge.
                                          Voltajes:
                                          PP3V42_G3H = 3.3v
                                          PPBUS_G3H = 12.2V
                                          PM_PWRBTN_L...
                                          06-28-2023, 07:41 PM
                                        • dionzarek
                                          PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                                          by dionzarek
                                          Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                                          I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                                          When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                                          Any help to where should I check on or suggestion would be very appreciated....
                                          02-08-2025, 11:00 PM
                                        • vdrokko99
                                          MBP wont turn on Only green light on charger
                                          by vdrokko99
                                          I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                          SMBUS_SMC_BSA_SCL 3.5V
                                          SMBUS_SMC_BSA_SDA 3.5V
                                          12-01-2024, 12:18 PM
                                        • ruletero
                                          HP Omen only do not turn on, only flashes white light
                                          by ruletero
                                          Hi everyone
                                          Please help me with this laptop
                                          HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                                          It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                                          But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                                          Bios was programmed with a working version, no changes.
                                          Voltages
                                          +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                                          06-07-2023, 10:11 AM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
