Technika 32" Failing to start with remote !
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Technika 32" Failing to start with remote !
    thats a good price too be honest hope it sorts the issue out.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Hey the new board came in installed it and it powered on and shut off about 5 times, fires up fine and is now working great, thank you all for you help )
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I spoke too soon the tv powered on fine with the remote but now the remote wont work the new board at all any ideas how to program the remote to it ?
        • vinceroger69
          • Mar 2012
          • 6714
          the remote should not need programing to the board at all if a genuine/replacement one have you tride the camera phone trick to see if the remote is transmitting? is the remote the genuine one for the tv or a universall one.The only other thing i can think of is maybe the cable from the main board to ir receiver is faulty?
          see toms post
          i forgot you may have used another tv brand/make mainboard i usually just order for the same tv brand/model
            If you put a Hitachi main board in this TV it will want a Hitachi-Vestel set of codes (they are slightly different.) You could try swapping EEPROM chip if it is in a socket. It's an 8 pin device mounted into a little socket.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              All done swapped that little chip and it powers on fine now and all functions work, thank you all for you help I will post a youtube video showing it working.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Got another problem now the tv will shut off during use, found that the 24v line is failing when it dies it causes the inverter to shut off and the speakers to crackle and the set remains in stby, tracked it back to the voltage reaching the rectifyer is too low and drops. Im just going to replace the psu, cant be bothered to track down the problem as I will be replacing the set at the end of the year.
                  If you do want to fix the issue it's probably the little 15n capacitors near the transformer on the PSU, common fault on this model.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    I have a few spare 17pw20's so when I get home im just going to swap it out and maybe consider repairing it, all these problems come on at once surprised it lasted 7 years with out a single problem so I cant complain Im going to replace it at the end of the year.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      Just an update I have decided to replace the set with a 40inch lg or sony as I suspect the tcon is now at fault as the set went blank backlights turn on but nothing is displayed so im scrapping it for parts as im putting more money into it even though I was going to replace it at the end of the year got 7 years out of it so im not complaining, thank you all for your efforts.
                      Image 1 showing a new main board and psu installed.
                        I'd say stick it on gumtree for free or £10 so someone can fix it, it may be a bag of rubbish but if it can be saved from landfill, that would be best.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          I have parted the unit out and have I will be selling or using its parts.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Got another one with the same issue, its a sanyo cd42ld33 with the same mobo but this has a 17pw16 psu and slave and master inverters. The set would fail to start with the remote and will shut the backlight down after it heated, but the Bl on voltage and 24v still persists but the led on the front flashes just like my technika did. So I decided to starting checking the inverters as they were darfons just like my technika and lone behold I find two 054n50's that generate the high current ready for the transformers tha were leaky and where heated just plain go open, I replaced them with the same parts off another inverter, the set fires on with the remote and runns fine for hours on end, been running and turning it on and off with the remote for hours. Wish I would have checked the inverter on the technika could have been simple but I over looked it as I had many tvs I could use in its place, wierd fault but thats vestel for you hope this helps.
                            • Mc_Millian
                              Toshiba 50lf711u20 fire tv remote not pairing
                              by Mc_Millian
                              I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                              The Tv model number is: 50lf711u20 Rev B.
                              I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                              I've tried 3 different remotes which should be fully compatible with this TV.
                              Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                              The power button, along with the volume,back,select, and directional...
                              04-07-2022, 12:15 PM
                            • unimatrix93
                              Technika T32HD-278-17 (VESTEL)
                              by unimatrix93
                              Hello everyone!
                              My crappy Technika TV has a flashing red light symptom. Black screen, Voltages looks good.
                              Does anyone have the EEPROM bin file for this model?
                              Technika T32HD
                              MB: Vestel 17MB140
                              Panel: VES315WNDA
                              Thank you!
                              06-16-2022, 04:11 AM
                            • cstout
                              DeLonghi AC Remote only accepts 3V
                              by cstout
                              Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                              The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                              I can't find any schematics...
                              06-03-2024, 03:53 PM
                            • Jaime Morillo
                              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                              by Jaime Morillo
                              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                              The TV was stuck on the logo and I couldn't access the update menu.
                              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                              The image result was good, but the image is inverted.
                              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                              08-18-2025, 11:38 AM
                            • edugimeno
                              HiSense 55A7500F won't obbey to remote after power on
                              by edugimeno
                              Hi! I have this TV set that does the following:
                              1) I press the red power button on the remote
                              2) The TV turns on normally
                              3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                              4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                              Then after it's off, it would again accept the TURN ON from the remote and same again
                              BUT:
                              -The remote does show the correct IR beam while observed thru a phone camera
                              -The TV works fine while using the MiRemote...
                              03-14-2023, 11:22 AM
