Philips 40PFK4100/12 CI key fail error
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    TV Philips 40PFK4100/12
    Chassis TPN15.E LA
    Hello everyone.
    I am facing a red message above the screen permanently, also the image is greyed and the TV is unusable as is in any sources.
    Of course I tried everything basic or a bit advanced, so I updated the firmware to version 2.550 which did not resolve the problem.
    Accessing the secret menu by
    Home+1999+Return
    I have access to 3 interesting parameters regarding this issue
    -DRM Warning
    -CIPlus Query
    -CIPlus update
    Obviously I tried to set DRM warning to OFF but this don't sustain, when closing the service menu it always set it back to ON
    CIplus update leads to an update error .... I did not expect anything other, though I found a key on some forum ...
    CIPlus Query this one is interesting, it shows :
    HTML Code:
    Valid: no
    Customer code:
    Serial Number:
    Then customer code and serial number are blank, how comes !? For me it shows clearly a corruption in the NVram. Perhaps the previous owner bricked the TV set with some junk or modified update or possibly a simple corruption.
    Then the next step was to enter in the hotel menu doing
    Home+062596 + OK
    there is nothing capital, except to erase fault codes, that does not resolve anything obviously.
    what do you suggest next, I guess it is now time to burn the chips onboard with a good dump ?
    Thanks for your tips.
  • Diah
    • Feb 2013
    • 6614
    find CI+ or CI Module and insert it at socket.. then do again what you did before
    • yoritomo
      • Sep 2012
      • 155
      • Belgium
      I don't have any, it is not in use in Belgium, it should not need it anyway. what would it change ?
      • lotas
        • Jan 2016
        • 4918
        • Russia
        Have you updated with the three-file firmware EmptyBurn_package 2in1_V2.550?
        • lotas
          • Jan 2016
          • 4918
          • Russia
          Chassis TPN15.E LA
          To save, you don’t need to exit the menu, but pull the plug out of the socket, then the changes will be saved.
          Try again in the 13th point Virgin Mode press OK, the TV will think for a bit and reboot with the initial factory settings as from the store
          • yoritomo
            • Sep 2012
            • 155
            • Belgium
            Hello
            Thank you both for your replies.
            Every updates I could find was in a zip comprising the three files which I copied to the root of the USB stick and installed by the update option of the normal menu.
            Yes I forgot to mention I already used "Virgin Mode" in combination with "DRM Warning off" , no success doing that.
            • lotas
              • Jan 2016
              • 4918
              • Russia
              Do you have such an update, we tried it "EmptyBurn_package_with_2.330.zip", which contains 11 files?
              • yoritomo
                • Sep 2012
                • 155
                • Belgium
                No I did not find yet a such full update.
                • lotas
                  • Jan 2016
                  • 4918
                  • Russia
                  Sent it to me in a private message.
                  • yoritomo
                    • Sep 2012
                    • 155
                    • Belgium
                    I installed the new update, no change except it has no more option in the secret menu to disable DRM Warning ...
                    I had an Idea, if the CI key is calculated on the serial number, it might be interesting to grab the Serial number of the donor TV to associate to the dump containing the key, despite to find the calculation algorithm
                    • Diah
                      • Feb 2013
                      • 6614
                      this is register.. doesn't have to do with Firmware... if the register lost we need to have it back at function Module , this why you have always No Signal
                      try change region to germany
                      • yoritomo
                        • Sep 2012
                        • 155
                        • Belgium
                        Diah : the only place the country can be changed is in the channel search, it did not solve anything, anyway the problem is general to every sources. The signal by HDMI or USB file is there, I can see the Image but darkly greyed.
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          The TV does not turn on, the standby indicator is on. All voltages are present.
                          Emms is dead. Not readable, not detected.
                          Replaced emmc.
                          But with another dump there is no launch
                          Terminal log
                          UART
                          AC_ON
                          RPMB key is not yet programmed
                          HASH1_VERSION=0x00000000 64bit
                          E-B
                          FDE enabled
                          layout pattern onebin by SAR7,0...
                          06-01-2025, 02:11 AM
                          LCD LED TV Service Menu Codes
                          ALL LCD LED TV SERVICE MENU CODES
                          Service Menu Code with Board Name
                          China Universal Board / Jumper Board Service Menu Code
                          Changhong Ruba Service Menu Code
                          Ecostar LED TV Service Menu Code
                          Orient LED TV Service Menu Code
                          Haier LED TV Service Menu Code
                          TCL LED TV Service Menu Code
                          Samsung LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          Videocon LED TV Service Menu Code
                          Supra LED TV Service Menu Code
                          Toshiba LED TV Service Menu Code
                          Symphony LED TV Service Menu Code
                          Veste/ LED TV Service Menu Code...
                          10-31-2024, 03:58 AM
                        • Ierwin
                          Philips 58PUS7805 Menu working but no/weird picture from video sources
                          by Ierwin
                          I got a 58pus7805 that shows some weird behavior.
                          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                          I managed to install the latest official firmware by holding the control button while plugging...
                          03-10-2024, 12:50 PM
                        • osman68i
                          Philips Coffee Machine PHILIPS EP5441 1.9.30.330.0
                          by osman68i
                          I need some advice about mainboard of Philips Coffee Machine PHILIPS EP5441 with 1.9.30.330.0
                          u2 is shorted. I can only read MX1 . cable goes to display panel....
                          Today, 01:55 AM
                        • TheUser
                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                          by TheUser
                          Hello to everyone ,
                          This is my first post here, and i would like to share with you a small story in case you can help me.
                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                          02-10-2024, 02:07 PM
