Philips 47PFS7509/12 LCD TV problem
  • janos6662000
    • Mar 2015
    • 33
    • Romania
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the TV does not boot to menu, i get the Philips logo and stays there forever.
    It is not dead, because i can rewrite the firmware as many times i want, but...
    I noticed one thing. When i power up the TV with the firmware update stick, i get the "Software update in progress" message.
    This goes for only 30 seconds, then TV restarts. Second time the process is much longer, but i think the time differs, i noticed that after 4-7 minutes the TV restarts again, this time to logo, no more "Software update in progress" message.
    I left it even 30 minutes, nothing happens.
    If i power it down and power it up, i can redo the process, but same happens.
    If i remove the USB stick, i get only the logo.
    I think that it is an emmc issue, but any idea is welcome.
    Maybe i could make an RS232 connection to check the boot messages?
    Please share your ideas.
    Thanks in advance.
    Best regards,
    Janos
    • 12206
    • U.S.
    what kind of signal are you trying, tuner, hdmi, if hdmi did you try another cable?
    Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
    • janos6662000
      • Mar 2015
      • 33
      • Romania
      Hello
      I was trying cable TV (european standard, RF to tuner), but now i cannot get anywhere, with or without a signal.
      What is also interesting, the TV has a Demo picture. When i selected that, got a nice picture, without restarting the TV.
      Now... only the logo, or the firmware update message.
        • 12206
        • U.S.
        Probably not it but won't hurt to try a simple reset. Unplug tv wait 10 minutes-hold power button on tv for 42 seconds-let go-plug tv back in and try it.
        • lotas
          • Jan 2016
          • 4618
          • Russia
          Connect via UART and watch the boot log, most likely the eMMC will die.
            • 12206
            • U.S.
            What's going on with the indicator light on the front of tv, blinking, solid, not on?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4341
              • Italy - Milan
              in recent philips the backlight can make the set to be in total protection, the difference between signal-no signal can be of dynamic B.L. that draws more current on a certain video, post eventually a list of signals on the power board connector, searchng for BL fault signal, this is the most possible for me that answers to fast degradation..
              • William1967
                • Nov 2017
                • 210
                • Netherlands
                The TPM14.X series are known for the bad caps in the power supply, several caps will be bulged.
                Another common problem is the software which makes the TV respond very slowly.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4341
                  • Italy - Milan
                  you can also try a slight warming of the bga area on the main board or power board, and also watch its solderings or hit it with the handle of screwdriver
                  • janos6662000
                    • Mar 2015
                    • 33
                    • Romania
                    Hello
                    I tried the reset, does not help.
                    I will probably try that. I need to build a cable. My UART connector seems to be on jack, being a 7500 series TV
                    While it is doing the firmware update, the led is blinking, sometimes slower, sometimes faster. When it has only the logo, the led is off.
                    You mean the Ambilight? I already disconnected that
                    • janos6662000
                      • Mar 2015
                      • 33
                      • Romania
                      I know it is not OK to judge the capacitors only by looks, but these seem perfectly OK. If you think there is a reasonable doubt, i can desolder the and measure/change them. I attach a picture.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4341
                        • Italy - Milan
                        i say backlight not ambilight, in the picture i do not see the bottom 4 pins label of connector, can you list them?
                        But first of all follow what William says , try to apply 12v from external PSU to the tv PSB 12v output, check if the ext psu goes in protection, there are some rare cases of el. caps. that goes short on a certain load, locating the bad dude is a bit complicated , so replacing them all can be an option.. instead of protected psu you can use bench psu with fixed current.. you can also contemporarily add a strong load like 12v 50w light bulb/s to increase curent in el. caps , or you can heat them..
                        • lotas
                          • Jan 2016
                          • 4618
                          • Russia
                          What does the backlight have to do with it if the problem is with the motherboard?
                          • janos6662000
                            • Mar 2015
                            • 33
                            • Romania
                            OK, this UART idea was brilliant, thank you.
                            I made a cable, connected to PC with Putty and made a log.
                            I already see some issues, but i am pretty sure that many if you will see the problem.
                            eMMC Name: UNKNOWN
                            Dev Num: 0, Timing Position: 1, Sample Edge: 0x00
                            Dev Num: 0, Timing Position: 2, Sample Edge: 0x00
                            : 0
                            *** Warning - bad CRC, using default environment
                            It may indicate a bad eMMC, but verifying the firmware update seemed OK.
                            Please analyze the log and advise.
                            I also attach a "normal", cold boot log, here i don't see that warning.
                            Best regards,
                            Janos
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4341
                              • Italy - Milan
                              i read it alll, also in working tv there are many "error" here and there, its normal, the only my suspect here is the DRAM B detected as 128mb, is it so by the chip marking? (the other one is 1gb)
                              ..at a certain point there is an "environment" error for low memory maybe.. and the program stops..
                              this tv symptoms leads to many fault types..
                              • lotas
                                • Jan 2016
                                • 4618
                                • Russia
                                "eMMC Name: UNKNOWN"
                                Either the eMMC is dead, or the processor does not see it.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4341
                                  • Italy - Milan
                                  if both ram are the same, try reflow at the ram 2 maybe
                                  • lotas
                                    • Jan 2016
                                    • 4618
                                    • Russia
                                    What does DRAM have to do with it, everything is fine with it, why re-solder it to kill the motherboard completely, what kind of advice is this? Here is the boot log of this chassis and the same thing.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4341
                                      • Italy - Milan
                                      what i read is the size of dram b is 128mb, i asked the user to check it first.. if you have a correct log then ok, i do not own every tv model of the world or do not have so much amount of informations.. (maybe i have to pay for them)!
                                      Anyway i don't like the polemic way of such comments.. i'm not here to destroy other people things, foget that manners please..
                                      • janos6662000
                                        • Mar 2015
                                        • 33
                                        • Romania
                                        The service manual mentions 3 DRAM's:
                                        DDR3#1-256Mx16-1600MHz (U402 H5TQ4G63MFRPBC)
                                        DDR3#2-256Mx16-1600MHz (U403 H5TQ4G63MFRPBC)
                                        DDR3#3-64Mx16-1600MHz ( U404 H5TQ1G63EFRPBC)
                                        So yes, i think, that the log reporting 2 different size DRAM's can be OK
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • Artefil
                                          HP officeJet 8012e ... A printer update will be installed to fix this problem
                                          by Artefil
                                          One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
                                          On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
                                          The screen displays the following message :
                                          "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
                                          But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
                                          Have you ever...
                                          09-28-2023, 05:11 PM
                                        • rumpumpel1
                                          ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
                                          by rumpumpel1
                                          Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
                                          10-24-2024, 08:59 AM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
