Philips 47PFS7509/12 LCD TV problem
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4467
    • Italy - Milan
    ok well 512mb x2 + 128mb, so the program stops for another reason, emmc appears ok as it flashes well all the software, but i stop here because of stupid bickering, good luck..
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • Artefil
      HP officeJet 8012e ... A printer update will be installed to fix this problem
      by Artefil
      One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
      On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
      The screen displays the following message :
      "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
      But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
      Have you ever...
      09-28-2023, 05:11 PM
    • rumpumpel1
      ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
      by rumpumpel1
      Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
      10-24-2024, 08:59 AM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
