Panasonic TH-L55ET60A
  • JohnML1975
    • Jul 2025
    • 30
    Hello and thought i would make a thread while i work on diagnosis of this TV
    TV has green standby light
    when i press on button, there is picture and no backlights come on
    the red light, starts to flash slowly
    there does not seem to a fault code that i can
    i removed the backpanel and many screws had to be drilled out as they seemed to be seized
    visual check of power, main, led, and t con boards reveals no damage or visible failure
    i disconnected the main board and bak lights did not come on
    i used thermal camera to look for any heat sources and found nothing interesting
    need to start working through voltages
    will share pictures later
  • JohnML1975
    • Jul 2025
    • 30
    Update
    there are no voltage check names from the power supply to the mainboard
    so i checked all fourteen pins
    i found voltages such as 1.9 and 3.3 and 5.5 so i think the power to main board is okay
    i found no 24 v going from main board to the led driver board should be four pins with 24v and these dont have the 24 v
    so i traced the 24v pins and these go straigjht to the cpu on the mainbaord
    i am going to heat the cpu at 300 degrees for 20 minutes on low fan speed
    shall try to reball the cpu this way and see what happens
    will update later
    • JohnML1975
      • Jul 2025
      • 30
      This was a fail for me
      after heating per above i allowed the board to cool
      placed back in the TV
      completely dead
      going to scrap and sorry this thread kind of went nowhere
      • nomoresonys
        • 12206
        • U.S.
        Yes that will kill it for sure, a typical reflow will gradually bring the solder to melting, the (time above liguidus) which is slightly above melting only requires about 60 seconds, so no wonder the chip is dead, 20 minutes is way too long.
        • JohnML1975
          • Jul 2025
          • 30
          Thank you so much for this advice. I have tried this around five times and everytime it failed.
          I did some research and found this video on reflowing
          will try on next chip
          How To Fix Your Dead Graphics Card Or Your Laptop GPU - DIY Reflow - Black Screen Artifacts Repair
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • David Smedley
            Panasonic FZ-55 Toughbook main board schematic request
            by David Smedley
            I've been working on this awful project with a Panasonic FZ-55, basically I'm trying to intercept the eDP signal from the main board, and replace it with my own eDP signal connected from an lcd driver. The problem is, for some reason the 30 pin ribbon pinout is really unusual and not playing nice with my LCD controller. Long story short, I managed to fuck up my board and pull off some pads on the eDP out port, I'm hoping to find either another eDP out source somewhere else on the laptop, or figure out this goddamn pin layout so I can just replace the whole native display complex with my controller...
            09-04-2024, 02:57 PM
          • dgnisbet
            Panasonic Tx-P50G20B faulty main board
            by dgnisbet
            I have a Panasonic viera plasma Tx-P50G20B which has a faulty main board. The picture freezes after about 30s and appears to lose vertical hold before finally going black. The main board part number - TNPH0838 (1) A - is common to several Panasonic tvs across a number of ranges however there is a second part number (TXN/A1LTUB for the 50") which is unique to each model.
            My question is, given that the TX-P50G20B 50" differs from the TX-P46G20B 46" only in the physical size of the screen, is it possible to use the main board from the TX-P46G20B in a 50"? The secondary...
            02-03-2022, 02:01 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
