Vizio E321VL flashes vizio logo on screen then just a blank, backlit black screen.
  • triplefour
    • May 2014
    • 1747
    got a Vizio E321VL today from the E-waste recycler for 10 bux to play around with/ hopefully repair and sell to buy some better tools.
    when plugged in, the vizio LED light glows orange.
    when press power, it turns white
    the backlights come on
    the screen displays the VIZIO logo for a second or 2
    then the vizio logo goes away and its just a blank, backlit, black unresponsive screen.
    pressing menu or any button for that matter does nothing.
    only way to turn it off is unplugging it.
    first impression is this is some kind of motherboard problem.
    what on the motherboard would cause such symptoms?
    i just got the back off. will post more pictures next.
    Don't fear the repair...
  • triplefour
    • May 2014
    • 1747
    Re: Vizio E321VL flashes vizio logo on screen then just a blank, backlit black screen
    ok heres pictures of the boards. i guess the TCON is built into the motherboard on this one.
    http://www.ebay.com/itm/Repair-Kit-F...item338caabced
    this eeprom chip might be the problem but the symptoms he lists are different than mine. the vizio logo doesnt stay on the screen when it freezes...
    • mu2
      • Oct 2009
      • 217
      I have the same set with main board 3632-1512-0150.
      The symptoms you have are the same as my set. I took a chance and ordered the eeprom.
      It did NOT fix the issue.
      Haven't been able to fix this one yet.
      Mike
      • triplefour
        • May 2014
        • 1747
        ah jeeze well lets try put our heads together and fix it? or is it sometimes the mainboard is just too tricky to diagnose and u gotta get a new one?
        did u make a thread for it?
        • 1beertap
          • Mar 2009
          • 219
          I too, have this set with the same symptoms as you guys. I turn on the TV and the backlight shuts off after a couple of seconds. A flashlight test reveals the screen is on. I can make the backlight come on by taking the third from the end "on/off" wire located on the power supply off and reconnecting it while power is still on. The TV works great from this point onward until I shut it off and turn it back on again.
          • triplefour
            • May 2014
            • 1747
            that is a weird symptom, luckily you found at least some kind of fix. but that is not the same as the symptom i am having. the backlights never go out. the vizio logo just disappears and then im left with a blank unresponsive but lit screen.
            • triplefour
              • May 2014
              • 1747
              hmm what should i test?
                • 31190
                maybe the software is corrupt.
                search for an eeprom dump.
                • triplefour
                  • May 2014
                  • 1747
                  i can reprogram the eeprom myself?
                    • 31190
                    parallel port can usually be used with wires to the chip.
                    • triplefour
                      • May 2014
                      • 1747
                      that sounds awesome...but id have to have an old PC that has a parallel port... and some software...and the rom.. where do i start?
                        • 31190
                        start by finding the romdump.
                        because without that, the rest is pointless.
                        • triplefour
                          • May 2014
                          • 1747
                          haha success! guess the rom dump adeventure will have to be saved for later. thanks to reading this thread: https://www.badcaps.net/forum/showth...t=20864&page=9
                          where the guy eventually fixed it by replacing/repairing the ribbon cable that went to the IR board, i decided to have a look at mine.
                          when i removed it i noticed the IR board was all rusted and corroded. i removed the board entirely, and now the TV starts up just fine.
                          crazy! how could the IR board halt the whole thing???
                          *victory dance*
                          that was too easy i like the hard ones where it takes weeks and i really learn something
                          LOL
                          edit: i guess i did learn something: CHECK THE IR BOARD!!!
                          oh and that rom dumping is theoretically possible
                          • mu2
                            • Oct 2009
                            • 217
                            triplefour,
                            This is a great forum!
                            I went back and looked at my E321VL. I disconnected the ribbon cable going to the IR board and the tv booted up correctly.
                            I took out the board and found that the ribbon cable wasn't seated correctly in the connector. In other words it was at an angle instead of straight in - I removed and reseated the cable.
                            I'm happy to say that the tv is working including the remote!
                            Thanks again to everyone that contributed in solving the issue.
                            Mike
                            • triplefour
                              • May 2014
                              • 1747
                              so crazy that such a trivial thing would halt the boot process of the TV but there u have it. check the simple stuff first! love this forum!
                                Good job finding the fault.
                                • triplefour
                                  • May 2014
                                  • 1747
                                  thanks budm...now if only i could figure out whats wrong with these other ones! specifically the samsung that has an intermittent problem https://www.badcaps.net/forum/showth...t=38339&page=6
                                  • Scary.McGarry
                                    • Jan 2015
                                    • 3
                                    I'm having the same issue but once the Vizio logo goes away and the screen goes black it still works except you can't see anything. I've reseeded the cables from the mail board to the back light board. When I get home I will try reseeding the IR Board and see what happens. Besides that does anyone know what is going on, why the backlight would work for a few seconds and just turn off?
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      when you say you cant see anything, do you mean that the backlights have gone away, but you can use a flashlight to see picture on the tv? if thats the case, then you have a different problem than i had. all i had to do was remove the IR board from the equation and the TV worked fine (except no remote till replaced that board)
                                      if your screen doesnt stay backlit like mine did, then its more likely you have a "2 seconds to black" problem, which honestly i havent quite figured out how to tell if its bad lamps or bad inverter. if the inverter board is getting the 24v from the PSU and the BLON (backlight on) signal as well, then you can safely say its not the PSU, but then u have to figure out if its Inverter or Backlights. you can test the transformer windings on the inverter transformers, and hopefully find the problem. but other than that, you have to replace the inverter with a known working one to really be sure...or take apart the panel to get to the backlights to see if you can see one is cracked or blown or something. (taking panel apart is really tricky though and easy to mess something up putting it back)
                                      theres also a way to test the transformers with a regular home CFL bulb and a wire... but i never did get that to work for some reason. read this thread for more tips:
                                      https://www.badcaps.net/forum/showth...903#post519903
                                      but dont post in it. make a new thread for your TV.
                                      • Leadguitarist1990
                                        • Aug 2015
                                        I am having a very similar issue with my e371vl. It starts up to the Vizio logo on the screen blinks once and then goes back to a black screen. I can still shut the tv off by pressing the power key on the tv. I've noticed by removing the rear cover that there is a little blue led light on the back of the power board. When the screen goes black after displaying the logo for a few seconds this little blue light fades away. I tried unplugging multiple ribbons and cables from both boards and checked all connections and I always get the same thing. I'm pretty handy with a multi meter and a soldering iron. I could just use a little guideance in my quest to fix this tv! I have searched hours on end through the inter webs and can't find anything that is exactly like what I'm experiencing!! Someone please help me! Thanks in advance!!
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • abajor
                                          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                          by abajor
                                          Having this very weird issue.
                                          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                          I swapped with a working screen from an A2141 waiting for parts.
                                          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                          04-27-2024, 01:37 PM
                                        • mecha1166
                                          Vizio V585-J11 & V585-H11 Blank or tie-die image on screen
                                          by mecha1166
                                          Hello, we have 4-6 of these sets now. All have blank screens, or slow-moving colors (looks like tie-die shirt). Some have narrow white lines and color around it.
                                          We have tried a new main and several tcons (2 exact and 2 similar). Same thing. Probably a panel - has anyone had this issue? These are fairly new sets, all but one came from rental.I own one, it was junked out. I tried searching for this model in forums but the search showed no threads for this model number. Thanks for any input!
                                          07-14-2023, 07:23 AM
