Samsung QE65Q700TATXXC is not starting
    Posted Photos 6 Photos
  • re-atari
    MSI A520M Pro mainboard - need boardview and/or hires photo's of components surrounding RT8894 PWM controller
    by re-atari
    Recently I was donated a defective MSI A520M Pro rev. 1.0 mainboard, that I am now trying to get back on its feet again. The error description when I received it, was that it wouild not boot, with the CPU error led lighting up.
    When inspecting the board with a magnifying glass, I noticed someone had slipped with a screwdriver when installing the CPU cooler. Not just once, but 2 times at that. Go figure. In the end the result was 2 scratches with damaged copper traces and a few knocked off (and missing) components around the RT8894 PWM controller. No wonder the...
    Yesterday, 11:58 AM
    09-07-2024, 05:50 AM
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • bohaboha
    ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
    by bohaboha
    Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
    04-19-2025, 01:47 PM
    09-06-2024, 11:40 PM
