insignia ns-l32q-10a wont turn on
  • jrp070282
    • Aug 2014
    • 9
    • usa
    tv would not power on and no standby led. i replaced the power supply and nothing then replaced the main board and only get the red standby led tv wont power on i tried both power supplys and still just get the red led staying solid any ideas?
  • jrp070282
    • Aug 2014
    • 9
    • usa
    Re: insignia ns-l32q-10a wont turn on
    could the t-con board or inverter board cause this?
      You can disconnect the cable between the Main and the T-CON and see if the you can turn TV on and off and will get the backlights. You can still have possibility with bad used main board, hopefully you get the correct board that matched the original.
      You will also need to look at the main signals: PS_ON, BL_ON to see if they are present when TV is turned on.
      • jrp070282
        • Aug 2014
        • 9
        • usa
        i disconnected the cable and all i get is the red standby led still wont turn on. i got the 715g33269-1 main board i ordered the same number board it is identical but at the top of the new board it where the t-con board connects it has another place for a cable to hook up (the original has the spot for it but the connecter is not actually on the board like the new one)
          Did you use the numbers as printed on the badcode (for PCB sssembly, blank board stuffed with parts) or the numbers (white numbers) as printed on the circuit board (which is the PCB number for blank board)? The one on the barcode is the PCB assembly (blank PCB stuffed with parts for particular PCB assembly), the black board can be stuffed with a bunch of parts to make a bunch of different PCB assembly for the TV model as needed. That is why the connector is not in the same location as the original.
          • jrp070282
            • Aug 2014
            • 9
            • usa
            the white numbers everything else looks the same the new one just has another connector beside the t-con board connector i did notice there is a barcode in middle of the board and the numbers are the same except for the orig. is v2.05 and the new is v2.07 there is also a barcode next to the white numbers and they do not match at all
              As you can see from SJ site: the warning about the P/N.
              "Partial part number (TQ9CBZK019) is found on barcode sticker."
              "Partial part number (TQ8CBZK027) is found on barcode sticker."
              There are more than one versions of this model:
              http://www.shopjimmy.com/catalogsear...ia+ns-l32q-10a
              So I cannot tell what you have.
              • jrp070282
                • Aug 2014
                • 9
                • usa
                the orig is tq8cb zk027 top:a mb:a v2.05
                the new is tq8cb zk034 top:a mb:a v2.07
                with the numbers not the same and it being a different v would that make it not work or are the compatible with each other?
                  I cannot tell unless you have the diagram of the board to see why they are not the same.
                  So you have PCB assembly "tq8cb zk027 top:a mb:a v2.05", you may be able to use PCB assembly tq8cb zk027 version2.06... 10 or what ever.
                  But the new board does not have the same base number, you have PCB assembly "tq8cb zk034" version V2.07.
                  They make more than one assemblies for reason, if they are not needed they will not be making them since it costs money to keep track and stocking bunch of assemblies.
                  • jrp070282
                    • Aug 2014
                    • 9
                    • usa
                    thanks i think i will get a board like the original and give it a try. if it still does the same what would the next step be?
                      Just have to put in the right board fisrt, BTW, was this TV worked on by someone else before and did it just quit by itself?
                      Make sure the new board is warranty, you cannot never trust Ebay seller, they always say tested working board which means they must have lots of TVs to put the boards in and test ALL the functions which almost impossible to do.
                      • jrp070282
                        • Aug 2014
                        • 9
                        • usa
                        no it was given to me by my grandma she said she thinks lighting hit it but there are no obvious burn marks on or under any of the 4 boards it would do nothing not even the standby light replaced the main and got the standby light( Solid red) when hit the power button nothing soild red light stays on
                          Lighting surge can damage lots of component, especially the HDMI IC for the HDMI ports which most TV uses to connect to the cable box.
                          32" Insignia is not worth very much, so I hope you do not put too much money into it unless you want to use it as learning experience.
                          • jrp070282
                            • Aug 2014
                            • 9
                            • usa
                            thanks again for the help ill post again when get the new board in and see what happens
                            • PNI E.
                              Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                              by PNI E.
                              Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                              03-17-2025, 04:23 AM
                            • madsox
                              Harman Kardon AVR 171S - standby led lights up, does not turn on
                              by madsox
                              Greetings!
                              Thank you in advance for your understanding, I am writing to you through a translator.
                              A Harman Kardon AVR171S amplifier was given.
                              The history of the machine is as follows:
                              It was faulty when I bought it, I want to fix it.
                              I replaced the HDMI switch and one of the DAC ICs in it.
                              After that it worked without a problem.
                              I watched a movie using the amplifier, and at the end the amplifier got really hot.
                              The cooling was faulty, I will fix this later.
                              I switched it to standby mode, waited for...
                              09-24-2022, 10:46 AM
                            • maxim2511
                              LG 55EC930V OLED - swich on swich of no screen
                              by maxim2511
                              My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                              Then I get an idea to take it apart and clean boards from dust.
                              In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                              Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                              05-14-2021, 02:21 AM
                            • AleMonti
                              LG 55EG910V - no power and no standby light
                              by AleMonti
                              I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                              I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                              The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                              After checking the basics I did the following:
                              • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                              11-04-2024, 05:02 PM
                            • cheeky2
                              by cheeky2
                              05-25-2024, 03:27 AM
