Philips 42PFP5532D/05 blue light only, 7 blinks on PSU LED
    Nice one from Gumtree this afternoon - blown fuse on power supply. Replaced the fuse (after checking for shorts - none found.) Diagnostics LED on PSU flashed 7 times indicating a fault with D5V. That is just the first voltage in the chain that is fired up, and that fails immediately, so the set faults back to a 7 blink error. Note main power light does not show an error code.
    The set will start and run with a dim image with a bulb in series too, which is nice.
    Picture quality is decent; not stunning, but pretty good. 720p 42" Samsung panel.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Philips 42PFP5532D/05 blue light only, 7 blinks on PSU LED
    a nice easy fix tom ive never owned any philips sets will you keep it a while on test before you sell it i tend to repair a set then use it as a bedroom tv etc for a week or two to make sure no intermitant faults show up. Ive just looked on gumtree some good bargains to have, but as ive got about six sets here to sell i cant really buy anymore projects at the minute lol (also my cars due mot soon and ive got to strip and repair the diesel pump so thats going to keep me busy too).
      Philips sets are pretty decent and nice for repairing - shame they've gone the way of a rebadge merchant now with their lower end sets but they do at least make some higher end models themselves. I usually test the sets for a couple of days before advertising and give the buyer a 30 day no quibble return guarantee.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        thats good then offering a gaurantee like that whats selling better at the moment plasma / led or lcds in your opinion (used sets).
          LED/LCD, plasma is a lot harder to shift.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            yes some good bargains regarding plasmas on my local gumtree as people cant sell them i guess hardly worth fixing the older types now then if cant make a profit although gaining the experience in fault finding and repair to component level is always worth doing i guess.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              I had one of these with that Samsung Psu (video to come soon) failed Fet on the Pfc boost converter however it didnt blow any fuses but cause the D5v going to the control board not to work lol gave 7 blink error as well.
              • Elecfronicsssss
                DA0NJJMBAG0 charging light blinks
                by Elecfronicsssss
                Laptop motherboard DA0NJJMBAG0
                PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                GUIDE ME WITH THE PROBLEM..
                SUMMARY-
                1.NO 1.8VOLTS ON BIOS PIN NO 8.
                2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                05-12-2025, 02:32 AM
              • Tomylee
                Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                by Tomylee
                Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                Here's what I've observed:
                All ribbon cables are properly connected
                Battery is present and in good condition
                No reaction even with screens disconnected
                There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                06-26-2025, 02:33 PM
              • jean luc ferre
                acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                by jean luc ferre
                on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                i tried the hard reset, cmos reset, changing the ram without results.
                in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                Yesterday, 03:54 PM
              • blind2reply
                proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
                by blind2reply
                proscan 40ld45q
                Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
                After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
                No sound, no picture (used flashlight test).
                No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
                Digital voltmeter;...
                06-06-2021, 01:16 PM
              • TurboTundra
                PS5 EDM-033 Blue Light 2 Sec then Powers Off
                by TurboTundra
                Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
                The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
                Thank you for any input...
                06-10-2025, 08:51 PM
