Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
  • howardc64
    • Jun 2017
    • 683
    Eventually discovered a burn mark near lower corner of LCD. Here is a summary
    • Backlight on, no image
    • Disconnect right buffer board (view from front), left side display comes on
    • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
    • Buffer board is pretty simple
    Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright spot above burn mark on LCD is just flashlight reflection getting the area lit for pictures.
    Since the panel is defective, only salvage parts.
    Click image for larger version  Name:	IMG_4680.jpg Views:	0 Size:	2.80 MB ID:	3680343 Click image for larger version  Name:	IMG_4678.jpg Views:	0 Size:	4.21 MB ID:	3680344 Click image for larger version  Name:	IMG_4677.jpg Views:	0 Size:	2.60 MB ID:	3680342 Click image for larger version  Name:	IMG_4679.jpg Views:	0 Size:	4.44 MB ID:	3680345 Click image for larger version  Name:	IMG_4681.jpg Views:	0 Size:	3.77 MB ID:	3680352 Click image for larger version  Name:	IMG_4682.jpg Views:	0 Size:	4.38 MB ID:	3680353 Click image for larger version  Name:	IMG_4686.jpg Views:	0 Size:	3.79 MB ID:	3680354 Click image for larger version  Name:	IMG_4687.jpg Views:	0 Size:	4.06 MB ID:	3680349 Click image for larger version  Name:	IMG_4688.jpg Views:	0 Size:	3.56 MB ID:	3680355 Click image for larger version  Name:	IMG_4689.jpg Views:	0 Size:	4.06 MB ID:	3680348 Click image for larger version  Name:	IMG_4693.jpg Views:	0 Size:	2.28 MB ID:	3680351 Click image for larger version  Name:	IMG_4694.jpg Views:	0 Size:	2.16 MB ID:	3680350
    Premium supporters get full download access and other benefits.
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • dumbdd
    Sony VA panel burn in
    by dumbdd
    I have a Sony 75x940e that I just fixed with the help of the forum (bad emmc). For the last couple of months I was noticing some burn in of the android home icons on dark backgrounds (photo is attached). I always thought VA panels were immune to burn ins. Is there anything I can do to fix it? Could it be because of a failing component other than the panel itself?...
    07-19-2023, 09:23 PM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • npielawski
    MacBook Pro late 2016 (820-00239) with multiple failure modes.
    by npielawski
    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
    10-15-2025, 01:53 AM
