Samsung LN52B75
  • phil@philporter.com
    • May 2013
    • 113
    Samsung LN52B75
    Had a power spike but see no signs on the power supply board - no bubbled caps and fuses show continuity. There is the small red light at on/off area in front of TV
    When I unplugged the ribbon cable to the main board the display lights up. How likely will another main board fix this problem?
    Re: Samsung LN52B75
    "When I unplugged the ribbon cable to the main board the display lights up" So the inverter, the backlights, and the power supply for the inverter are OK. So I would say you do have main board problem, but you should try disconnecting the LVDS cable between the main board and the T-CON and see if you can turn the TV on and have backlights.
      • May 2013
      • 113
      Re: Samsung LN52B75
      Replaced the main board. All works fine now. Thanks.
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
